Need Help Making Home Recordings
I want to be able to make multi-track recordings on my laptop but don't know the best way to go about it.
I have Cakewalk Home 2004 on the laptop but the sound card I'm using - SB External USB, has too much latency and I can't see how to monitor one track while laying down another. I see a bunch of audio interfaces online at Musician's Friend and others but don't know if you can make multi-track recordings with those or what the heck. I'm also on a very tight budget so under $100 is what I'm thinking. |
| Sponsored Links |
will you be tracking both vocals and instrumentals?
your interface isn't a limiting factor on multitracking, all it does is give a measure of control over the signal you feed into the computer. your software will give you all the tracks your hardware can manage. but with a budget interface, you'll probably have to lay down one or two at a time.
Truth is stranger than fact ... www.myspace.com/woodymitchellmusic BAND PAGES: www.myspace.com/stragglerswing (Stragglers - Western Swing) www.myspace.com/loafersgloryband (Loafers Glory - '70s country-rock) |
in that case, any affordable interface with both a quarter-inch jack and an XLR (low-z mike) input will get you started. don't have specific suggestion, but i bet some of the other more savvy guys do. entry-level stuff isn't too costly, but when you hit it big, the sky's the limit!
I just got the least expensive unit with an XLR and 1/4" instrument I was able to find. M-Audio Fast Track USB. Pro Tools is working at very little latency (256 sample buffer) and Abletron Live is not quite that clean but it was definitely worth $100.
"...You don't need faith if you know it's gonna work!" "The views expressed here are mine and do not reflect the official opinion of my employer or the organization through which the Internet was accessed." |
StuH turned me on to this driver for my soundcard:http://www.asio4all.com/
This solved my latency problem with no additional investment required. Thanks again StuH! Dan
Teles are like Mr. Potato head |
