Losing drivers
I got m-audio drivers installed did some recording, Great right? Turned it back on yesturday and the the drives for the m-audio are not showing up. I had to uninstall the other day and then reinstall. What do i need to do so they show up everytime. Thanks
| Sponsored Links |
I'm running windows xp. I've found out I need service pack 2 on my laptop. It has sp1 now. I wasn't choosing the right hardware either. Going to installed SP2 and then download latest drivers from M-audio tonight. Hopefully that will cure most of my troubles.
1. Check for updates to your M-Audio drivers, updates to the operating system and updates for the MC3 program.
If that doesn't work: 2. Before you even open Music Creator, unplug the M-Audio device from the usb port and plug it back in. If that doesn't work: 3. Sometimes having more than one sound device on a pc computer causes program confusion. You have two audio devices, your M-Audio device and the Sigma sound card. Use your M-Audio interface like it is the permanent sound card for your system. To make the M-Audio the default audio device. Start/Settings/ControlPanel/Sounds and Audio devices/ on the sounds and audio devices property dialogue box under sound playback select you M-Audio device output # (the output number your speakers are attached to on the interface) under sound recording select your M-Audio device input # (the input number your instrument is connected to) don't worry about midi music playback if that doesn't work: 3. Disable the sigma audio device in the hardware manager only if you know what you are doing. start/setting/control panel/system hit the "hardware tab" hit the "device manager" button hit the "+" button where it says "sound video and game controllers" look for a name that makes reference to your Sigma put your mouse over that name and right click and hit "disable" If that doesn't work: 4. Make sure you are not using a usb hub, plug into a usb port directly on th pc not an external hub Check for IRQ conflicts, maybe another device is sharing the same IRQ address. Not 100% familiar with this so can't help you here. It's a bit of a nerdy operation. |
I found all the problems. I had to upgrade to ServicePack 2 for my xp system. I was running SP1. Then I up loaded the most recent M-audio drivers and everythings good. I laid a simple song down in about one hour. I got to use the MXL 900 mic plus a few other things. Now I can take the time to figure a few other things; mainly, how to work the 1) metronone, 2) looping, and 3)mixing it so I can burn a CD. I hope I can sound has half as good has you guys around here. The cakewalk MC program seems pretty easy so far.
#7 (permalink) | |
"...You don't need faith if you know it's gonna work!" "The views expressed here are mine and do not reflect the official opinion of my employer or the organization through which the Internet was accessed." |
Can I suggest that you download and use Asio4all ?
It is pretty much a driver solution which allows everything to run from the same driver .
Homepage http://www.soundclick.com/members/de...member=flat357 MySpace http://www.myspace.com/flat357 |
