Old April 25th, 2008, 12:11 PM   #1 (permalink)
Daddydex's Avatar
Mastering Question
Hey guys. For do it yourself mastering do you just stick your plugins on the master track at the end of the mixing process or do you render to mp3 and then run the mp3 through the mastering plugins? I know if I have to ask that I am nowhere near being able to effectively master but I do like to mess with things.
Thanks,
Dan
Teles are like Mr. Potato head
Daddydex is online now   Reply With Quote
Old April 25th, 2008, 03:40 PM   #2 (permalink)
Big John's Avatar
I think 'whatever works with the gear you have' is probably the sensible answer.
I use Digital Performer 4.6 on a G4 Mac with the computer FULL of RAM,
i run any effects on each track as needed, i usually use one Reverb setting overall (to tie things together) but run it on an Aux track so can control it independently on each track then the only thing i have on the 'master out's' would be a fairly hefty EQ and then the L1 limiter.
I always master them to 'Sound designer II' or 'Aiff' format depending on where they are going.
If i'm making an MP3 i will start a new session, import the finished track, make any adjustments i think neccesary and export as Mp3.
If i think the machine is getting a bit bogged i might bounce some 'stem' tracks together, acoustic guitars or drums etc. i will bounce them down to a stereo pair to lighten the load.
Thats just MY system though and i'm sure we all have our own little quirks, i am after 'consistency' in my recordings so often make lots of notes on paper or on screen, there's nothing worse than thinking, "well, i did it yesterday and it sounded great, now, how the *&^& did i do it ?".
I was the part time 'Mac guy' at the academy of art in Cambridge for awhile and the students were constantly told "Keep a digital diary", if i had any advice to give that would be it, if someone likes 'that' sound you need to be able to re-do it.
Apart from that ----- if it sounds like you want then it's all good !
If you are going to be a bear, be a grizzly !!
Big John is offline   Reply With Quote
Old April 25th, 2008, 03:44 PM   #3 (permalink)
elmerbumpkin's Avatar
compress (to mp3) last
elmerbumpkin is offline   Reply With Quote
Old April 26th, 2008, 10:06 AM   #4 (permalink)
Daddydex's Avatar
Thanks guys, so it seems there is more than one way to skin a cat.
John, I have been using that reverb trick and it does add life to a recording.
Dan
Old April 26th, 2008, 10:55 AM   #5 (permalink)
octatonic's Avatar
Dan,
I mix to AIFF then have a separate process for mastering, which is send it to a mastering engineer in a separate studio.
I do however master projects that I haven't mixed for people who are on a budget.
I am not a professional mastering engineer- I track and mix, but simply having a new set of ears in a new acoustic environment is sometimes all you need to get a track to a releasable level.
The whole point of mastering it to get a second set of ears and most importantly in a separate acoustic space to address issues that are specific to the room you record in.
As a general rule you should NEVER master in the same room as you mix, unless that room is incredibly well designed and as close as acoustically flat as possible.
Say, for example, you mix in a room that is 23 x 16 x 10ft.
You end up with room modes at the following frequencies:
See the build up around 300-400hz?
That is going to mean the room is resonant at those frequencies.
You are likely to hear those frequencies more in that room and when you eq you will end up with a hole (because you will have compensated for them) in your recording.
A mastering engineer will have a much better room than you with a frequency response that is flatter and will hear this (if he is 1/2 decent) and be able to compensate for this.
What is your current mastering chain?
Apologies if this sounds overly didactic but mastering is not just about "making it louder", compressing it to sound bigger and trying to have it compete with commercial recordings.
It is a process whereby a separate acoustic environment and an experienced mastering professional can provide "musical balance" to a track- to redress the acoustic issues and mixing decisions that ultimately detract from the quality of the recording.
IMHO this cannot be done by 99.99999% of mixing engineers when they are working on their own material.
I'll offer to back this up by offering to master a track of yours with my mastering chain in my acoustically balanced studio- you can decide for yourself if I am talking out my backside.
I'll even give you a point by point breakdown of what I did and why I did it.
That was a little long winded, I know- and I am not trying to discourage you from experimenting but I would like to dispel some very common preconceptions people have about this process.
Mastering is more art than science but I'll outline my process here.
I take a track that is usually a 24bit 96khz AIFF and put it into Protools HD.
My HD rig has a lot of IO on it and all the outboard is connected so I can aux it into the Protools rig.
There is a patchbay in place so if I want to connect two pieces of hardware in series I can do it without having to pass through multiple A/D/A stages.
For compression I have my TDM plugins (Compressorbank, Sony Oxford compressor mostly) a stereo pair of
Empirical Labs Distressors, a Focusrite Red 3 and Compounder and a couple of cheaper units.
EQ I have some TDM plugins (Massenburg EQ, Filterbanks and a couple of others) and a Manley Massive Passive
There are some metering tools I use (Waves Paz and a rackmount strobe tuner) and some outboard effects (Lexicon PCM90, MPX1, Ensoniq DP Pro).
There are some other bits and pieces that might get used but that is the bulk of it.
Most plugins are unsuitable for mastering to any acceptable degree- I can't think of a time when I've used a Waves compressor or EQ for mastering with the exception of L1/2/3 which get their own section.
L1 (and 2 or 3) really changed the game- in the hands of someone who is experienced they can provide the missing bit of life to a track. Mostly though, they are overused and end up destroying the track- removing the dynamic range AND SOUNDING VERY SHOUTY ALL THE TIME.
Use with caution.
Anyway, I am happy to master a track and provide you with some real world advice as to what I did in that specific instance- let me know if you want to take me up on that.
Last edited by octatonic; April 26th, 2008 at 02:01 PM. Reason: Buggered up the room dimensions... fixed.
Old April 26th, 2008, 12:31 PM   #6 (permalink)
Daddydex's Avatar
Thanks Jim, I will absolutely take you up on that offer. Let me get my s*** together on my end and I will PM you. So you would want an AIFF file? I will have to figure out how to send it to you.
Also, maybe I should post the original file on Soundclick and then we can post the mastered take so everyone can benefit from your knowledge.
Great post Jim, you addressed some issues I didn't consider.
Dan
Old April 26th, 2008, 02:35 PM   #7 (permalink)
octatonic's Avatar
Dan
Hi Dan,
I always balk at making those kind of posts because 1) I know I sound a bit pompous when I do. 2) I'm really not like that. 3) I don't want it to sound like I am trawling for work.
I have my own websites with FTP- I'll create you an account and you can pop it up there.
We can post both versions for sure.
What if anyone else wants to have a go at it too- maybe we can turn this into a bit of a science experiment?
I have a couple of days next week where I am not doing much so if we can do it by then I can spend a bit more time on it.
Two more things I forgot to mention in my novel above.
1. Multiple sets of monitors. A very important component.
I have 3 sets of monitors- Some Genelecs, Some Dynaudio's and some B&W stereo speakers.
There are also boom boxes in the studio and in my house for reference mixing and I routinely go for a drive just to hear the tracks in the car stereo.
2. Remixing. Not in the "techno" remixing sense.
I have had mastering engineers suggest to me that I go back and mix tracks again when work hasn't been up to par.
Usually it is issues of bass management (I often mix bass heavy) or phase problems on the top end due to over-processing. Very important as a mix engineer to not be precious about it, listen to what they say and then get on with the job.
Old April 26th, 2008, 02:48 PM   #8 (permalink)
Daddydex's Avatar
That would be a fun experiment. If anyone else wants a go at it, let me know.
I will finalize the mix later tonight. The song is Bob Dylan's "I Shall Be Released".
Dan
Old April 26th, 2008, 11:55 PM   #9 (permalink)
Daddydex's Avatar
For those of you still following along, the mp3 is now posted on my Soundclick page:
http://soundclick.com/share?songid=6495269
When Jim has completed the mastering process I will post that version as well.
If anyone would still like to take a crack at mastering the song please let me know and I will send you a copy. I think it would be great to compare the different results.
Dan
Old April 27th, 2008, 12:19 AM   #10 (permalink)
Very nice.
DLGinSC is offline   Reply With Quote
Old April 27th, 2008, 12:50 PM   #11 (permalink)
Great job (although I may be accused of being biased!)....
barrel
barreloflafs is offline   Reply With Quote
Old April 27th, 2008, 01:23 PM   #12 (permalink)
Daddydex's Avatar
barrel
Folks, I give you my brother. About time you found this place! Now go buy a tele.
Dan
Old April 27th, 2008, 01:30 PM   #13 (permalink)
Dan
You meant to say BIG brother....
BUY a tele? Can't I just borrow one of yours?!!!
Old April 27th, 2008, 01:41 PM   #14 (permalink)
Daddydex's Avatar
Of course. But more importantly you can post a picture of my Les Paul.
Oh yeah, and find the recent thread on Silvertones.
Dan
Old April 27th, 2008, 02:13 PM   #15 (permalink)
Dear Mr. Richmond,
Your posts are very edifying and not pompous in the least. Please keep them coming, as these are the most coherent posts on mastering that I have encountered on the www.
I have a specific question on your item 2 below about remixing. 1) Are you talking about re-mixing a stereo pair of tracks, or the set of "raw tracks that make up the pair, or both?
2) Please elaborate a bit on this, "Usually it is issues of bass management (I often mix bass heavy) or phase problems on the top end due to over-processing. Very important as a mix engineer to not be precious about it, listen to what they say and then get on with the job".
3) When does mixing or re-mixing become mastering?
I'd also like to take a swing at mastering Dan's song, for the education it will bring.
Sincerely yours,
Bonneville Bruce
Originally Posted by octatonic View Post
Hi Dan,
"Let us issue, 'Live Music is Better' bumper stickers."
Bonneville Bruce is offline   Reply With Quote
Old April 27th, 2008, 02:19 PM   #16 (permalink)
Daddydex's Avatar
+1 about Jim. I was never put off by any of his posts.
Bruce, as soon as I figure out how to get the track to Jim I will get it to you. Thanks for playing along.
Dan
Originally Posted by Bonneville Bruce View Post
Dear Mr. Richmond,
Sincerely yours,
Bonneville Bruce
Old April 27th, 2008, 02:57 PM   #17 (permalink)
Dave_O's Avatar
+1 on what Bonneville Bruce said...
that was the most coherent explanation of mastering I've ever seen in 25ish years of recording. Back in "the day", when mastering was about getting stuff onto vinyl, no-one would tell you what they were doing. It was like some secret society!! In the digital realm, it's a different ballgame, but still a bit of a black art.
I'll take your advice onboard next time I do some recording.
Thanks Jim!!!
... I love this forum.....
The Hammer of the Honky-Tonk Gods
www.myspace.com/hardwayband
www.myspace.com/mojobros2mantrio
http://www.soundclick.com/davemilesandthehardway
... and preface everything I say with IMO,FWIW... and WTF
Dave_O is offline   Reply With Quote
Old April 27th, 2008, 03:28 PM   #18 (permalink)
octatonic's Avatar
Dear Mr. Richmond,
Sincerely yours,
Bonneville Bruce
Thanks guys...
1. Remixing in terms of going back to the original session data, the raw session data and doing it again.
2. The bold area I guess you added for emphasis so that is the sentence I'll answer.
Well, it is amazing how some mix engineers can be precious about their recordings. They sometimes view the mixing process as an art in itself (I disagree- I think it is an engineering task, not a creative process in itself, but the lines are blurred) and they will often ignore the advice of a professional mastering engineer because they believe their work is precious.
Mix engineers have to deal with the same sh1te from artists who view their songs as immutable universal truth and wont change a word or chords because it interferes with their sense of self.
Basically, mastering engineers make suggestions that should really be listen to by mix engineers if they want their mixes to improve.
Most mastering engineers spend more than 1/2 the cost of their studio on acoustic treatment.
They hear stuff that people like me don't.
Some people are too proud are arrogant to acknowledge that.
I admit, I had that attitude for a while, but I wised up to it- it gets you nowhere and mixing again takes only a couple of hours.
3. Well mixing a track again is nothing more than a suggestion a mastering engineer might make if the track he is working on isn't up to standard.
This happens from time to time, nothing to worry about- the worst thing I can do as a mix engineer is ignore that advice.
FWIW I usually do final 10-20 mixes of each track anyway- all with slightly different changes (vocals up or down by 1db, or any other instrument). It is normal.
Remixing occurs in my studio, not the mastering engineer's.
FWIW Mastering engineers are referred to as ME's- mix engineers are not, no idea why but I will write ME from now on and I mean Mastering Engineer.
I'm glad you guys appreciate my posts- my way is not the only way to do it of course, so this is all IMHO.
I post a lot on Gearslutz as well, as do a lot of industry pro's- you can get a hell of a lot of great information there although it is a bit less polite at times.
Old April 27th, 2008, 03:34 PM   #19 (permalink)
StuH's Avatar
Dan nice tune, it's your best by a mile.
Nice post Jim very informative, keep them coming.
StuH is offline   Reply With Quote
Old April 27th, 2008, 03:54 PM   #20 (permalink)
Daddydex's Avatar
Thanks Stu, I am still reading up on compression and Eq. I have a long way to go but thanks to you guys things are improving.
Also, I did finally upgrade my RAM to 2 gig (maxed out now). Good deal at newegg.com. The RAM made an incredible difference in Reaper. I also found out my computer will not support two monitors. No matter how much I kick and scream, it ain't gonna happen. I will keep my eyes out for a good deal on a widescreen flat panel.
Thanks again.
Dan
Old April 27th, 2008, 04:27 PM   #21 (permalink)
StuH's Avatar
Dan you have no available pci or pcie slots on your motherboard? Are you going to get ezdrumer?
Old April 27th, 2008, 04:29 PM   #22 (permalink)
Daddydex's Avatar
No. I guess there is a video card available that can supposedly do the job but it is reported to be very buggy. I will try to find where I read that.
Dan
Old April 27th, 2008, 04:39 PM   #
