Old April 1st, 2008, 05:27 PM   #1 (permalink)
sax4blues's Avatar
Trim setting for drum overheads.
I record drums with three mic set up, kick drum, 2 overhead. My question is how to set trim peak level on the overheads in regards to the snare. If there is no snare the trim can be turned up. With the trim up and playing the snare the peak is flashing with each snare hit.
What are some suggestions for finding the optimum setting?
sax4blues is offline   Reply With Quote
Old April 6th, 2008, 09:43 AM   #2 (permalink)
octatonic's Avatar
There is no optimum setting aside from not redlining if you are recording digitally.
If tracking to analog then there are a different set of rules, but I won't go into them unless someone specifically asks.
Old April 6th, 2008, 12:53 PM   #3 (permalink)
Moderator
Tim Armstrong's Avatar
Yeah, peak trim level is whatever doesn't clip!
Cheers, Tim
http://www.moodswingers.org
Old April 6th, 2008, 01:35 PM   #4 (permalink)
woodman's Avatar
you might try using EQ on your overheads ... a cut at 1K will back the snare off, and a boost at about 6K will bring out the cymbals.
BAND PAGES:
Old April 6th, 2008, 05:06 PM   #5 (permalink)
octatonic's Avatar
Depends on the room but I tend to boost around + 4.5 dB @ 10k for this.
Also, -6.0 dB @ 200 Hz will reduce tom and kick pickup in the OH's.
Both using a shelf.
Old April 7th, 2008, 11:57 AM   #6 (permalink)
woodman's Avatar
Both using a shelf.
excellent point on the 200 Hz!
BAND PAGES:
