Go Back   Telecaster Guitar Forum > Other Discussion Forums > Other Guitars, other instruments
Other Guitars, other instruments Use this forum to discuss all guitars and other instruments that are not Teles or Strats -- Fender, Gibson, PRS, you name it. If it's a Tele or a Strat see the appropriate Tele and Strat Forums here.
Old February 2nd, 2013, 03:35 PM   #1 (permalink)
ValveFan's Avatar
24" scale neck on a 25.5" scale body?
There's a frankenstein guitar on ebay that consists of a "standard" 25.5" scale strat style body bolted up to a 3/4 scale (24") neck. Will the intonation work out correctly with that combo? It's a Squier Showmaster body and a Duo-Sonic neck. I'm not all that serious about buying it but it made me curious.
My sustain problem went away once I rolled up my sleeves.
ValveFan is offline   Reply With Quote
Old February 2nd, 2013, 03:46 PM   #2 (permalink)
TheFullMonty's Avatar
Not unless he moved the bridge back an inch and a half. Which I imagine would be quite difficult with the trem routing in place for a 25.5" neck.
I saw Steely Dan back when they were on the club circuit.
TheFullMonty is offline   Reply With Quote
Old February 2nd, 2013, 03:48 PM   #3 (permalink)
Disregard that information. I just woke up from a nap and I'm not in my right mind.
Old February 2nd, 2013, 04:22 PM   #4 (permalink)
ValveFan's Avatar
Well, I can't remember the last time I was in my right mind...
So, are you saying it will intonate correctly, or you don't know? I appreciate you taking the time to reply in any case.
Old February 2nd, 2013, 06:32 PM   #5 (permalink)
twiggymac's Avatar
SHOULD be a conversion neck, which means it SHOULD be okay
~twiggy "walk on"
twiggymac is offline   Reply With Quote
Old February 2nd, 2013, 06:52 PM   #6 (permalink)
JasonRobert's Avatar
if there is a picture of the whole guitar, in a birds eye view (ie looking straight down).. then you could print off the picture, then measure with a ruler from the nut to the 12th fret. Then measure from the 12th fret to the point the string goes over the bridge (or where the string first touches the saddles). as long as the picture is taken fairly straight, the two measurements should be roughly the same. If they are miles out, then the intonation will be wrong.
JasonRobert is offline   Reply With Quote
Old February 2nd, 2013, 09:00 PM   #7 (permalink)
AussieAndrew's Avatar
Forget it and keep looking.
Andrew.
One mans trash is another mans treasure !
If it's busted fix it ~ if it's good make it betterer.
AussieAndrew is offline   Reply With Quote
Old February 2nd, 2013, 11:28 PM   #8 (permalink)
For it to work the bridge would've had to have been moved, or they wouldve had to use a conversion neck (24.75" I think, & I don't think fender makes conversion necks, I think warmoth does)
Cartoon Music Video
CrisHendrix is offline   Reply With Quote
Old February 3rd, 2013, 01:02 AM   #9 (permalink)
Nick JD's Avatar
"Conversion" necks are basically just the same as capoing the first fret.
The headstock is brought down 1.5"
Old February 3rd, 2013, 08:00 AM   #10 (permalink)
benderb9's Avatar
I had put a 24.75" Mighty Mite neck on a body routed for a Fender scale 25.5" neck and had to cut out the front of the pickup route to get the bridge in the right place. I'd suspect that you's have to cut a lot of real estate out of that Strat body to make it work.
benderb9 is offline   Reply With Quote
Old February 4th, 2013, 01:18 PM   #11 (permalink)
crazydave911's Avatar
Rondo sells them all the time.....................full size strat body with a conversion neck. It works...............no big gig
LINK
My Facebook
Old February 4th, 2013, 10:54 PM   #12 (permalink)
LINK
I just measured the distance between the nut & 12th fret, then the saddles & 12th fret. Major discrepency. About 2 1/2 frets worth.
It's just a short scale neck on an unaltered full strat body. Intonation will still be lacking.
Andrew.
Old February 4th, 2013, 11:20 PM   #13 (permalink)
If the rondo does work they could just be making the body with the bridge moved up
The problem is using a standard full scale fender body with a non-conversion short scale neck, something has to give
Cartoon Music Video
Old February 5th, 2013, 12:18 AM   #14 (permalink)
It's just a shorter neck...............that's all............on this one at least
My Facebook
Old February 5th, 2013, 01:02 AM   #15 (permalink)
Yeah, it'll work but it wont be very useful as the intonation/harmonics will be out. The centre of it's scale won't be at the 12th fret, it'll be closer towards the body at say, the centre of the 13th fret for example. The exact distance between the nut & 12th fret needs to match the distance between the saddle & 12th fret (exactly) for correct intonation. Give & take a poofteenth for the thickness of each string-the very reason why saddles are adjustable.
I 'spose it'd be OK for someone just starting out (playing open chords). It all depends on how fussy one is ~ I'm sure most stringslingers are pretty fussy. I am.
Cheers,
Andrew.
