Go Back   Telecaster Guitar Forum > Other Discussion Forums > Other Guitars, other instruments
Other Guitars, other instruments Use this forum to discuss all guitars and other instruments that are not Teles or Strats -- Fender, Gibson, PRS, you name it. If it's a Tele or a Strat see the appropriate Tele and Strat Forums here.
Old July 29th, 2012, 04:28 PM   #1 (permalink)
El Hefe's Avatar
Favorite palm sander
So what's your favorite palm sander? Looking to get one to finish striping my strat body.
El Hefe is offline   Reply With Quote
Old July 29th, 2012, 04:47 PM   #2 (permalink)
KevinB's Avatar
I have a variable speed, 5" Porter-Cable random orbit sander like this...
But as long as you stay with the top brands like DeWalt, Bosch, Makita, Milwaukee, Ridgid, etc., I don't think there's much to choose between them.
Old July 29th, 2012, 04:59 PM   #3 (permalink)
I have a Dewalt random orb that kinda looks like KevinB's. Just an on/off switch, not variable, but works good and I've used it for all kinds of projects.
"I've suffered years for my art. Now it's your turn.. One, two, three and..."
DuncanAngus is offline   Reply With Quote
Old July 29th, 2012, 05:29 PM   #4 (permalink)
Just be sure to get a random orbit sander: http://en.wikipedia.org/wiki/Random_orbital_sander
c.winn is offline   Reply With Quote
Old July 29th, 2012, 05:41 PM   #5 (permalink)
El Hefe's Avatar
I found this one, I like the price.
http://www.harborfreight.com/5-inch-...der-93431.html
Old July 29th, 2012, 05:56 PM   #6 (permalink)
KevinB's Avatar
You get what you pay for.
For $25 more you can buy a good one that will probably outlive you.
Old July 29th, 2012, 05:58 PM   #7 (permalink)
for electric it's a Porter-Cable, for pnuematic it's Dynabrade. I prefer the Dynabrade as I can get into tighter corners with it. Mine get daily use and get dropped several times a week. They are both rugged and dependable.
babalooga is offline   Reply With Quote
Old July 29th, 2012, 06:25 PM   #8 (permalink)
El Hefe's Avatar
Cool thanks guys I found a few better ones that I'm gonna look into. Any ideas on what's the best way to sand the inside of the horns on a strat?
Old July 29th, 2012, 07:51 PM   #9 (permalink)
Having done this, I'll throw out a different route.
Get a good respirator, a gallon of acetone, a bunch of 3M scratch pads, some thick stripping gloves, and prepare to make a mess. Elbow grease required. This is a nasty way or going about it, but you won't remove any wood. Lacquer thinner will eat lacquer, and acetone SHOULD take off poly. Then at the end you'll just have some minimal hand-sanding to do. I'd personally hate to sand off the entire finish on a Strat. You could very easily gouge/flatten/ bevel/re-contour the body. Those palm sanders will remove wood FAST. I'd end up bummed. The chemical route is toxic and messy, but effective. Wear that respirator!!!
B.G.L. is offline   Reply With Quote
Old July 29th, 2012, 07:54 PM   #10 (permalink)
I just re-read the op. Did you already mostly strip the body??
Old July 29th, 2012, 08:05 PM   #11 (permalink)
El Hefe's Avatar
Yea I only have the sides and insides of the horns to do, and a small area where I try'd out some stain but I didn't like it, so I've changed my mind and I want to paint it now. I'm gonna use duplicolor.
Old July 29th, 2012, 08:06 PM   #12 (permalink)
Inside the horns? I'd soak a bunch of different grits of automotive wet or dry papers in water overnight, then use naphtha as a lubricant for your sanding. Water will swell the wood. Again, wear the respirator.
Old July 29th, 2012, 08:10 PM   #13 (permalink)
I used Duplicolor on one of my earlier paint jobs. I ended up with fairly decent results. Dries like concrete, so the final wet sanding was tedious, but again, came out ok.
Old July 29th, 2012, 08:19 PM   #14 (permalink)
El Hefe's Avatar
Cool man, can you post some pictures?
Old July 29th, 2012, 08:26 PM   #15 (permalink)
I'll have to take some...
Old July 29th, 2012, 08:30 PM   #16 (permalink)
gtrguru's Avatar
Harbor Freight is great for a tool that you will only use a couple times.
-Music is only heard by those that listen.
gtrguru is offline   Reply With Quote
Old July 29th, 2012, 08:41 PM   #17 (permalink)
Old July 29th, 2012, 08:49 PM   #18 (permalink)
El Hefe's Avatar
Looks good!
What clear coat did u use?
Old July 29th, 2012, 09:27 PM   #19 (permalink)
No clear!!! I was going for a yellowed Oly White look. I just used the Duplicolor that was closest, got it white, wet sanded it smooth, and hand-polished it with some automotive polish. Meguiar's maybe, I don't remember. Up close it has lots of spider-web sanding swirls. It just looks like an old hand-polished axe. I just wanted it white, and at the time wasn't quite going for a pro finish. Smooth and shiny yes, glossy perfect no...
Old July 29th, 2012, 09:43 PM   #20 (permalink)
El Hefe's Avatar
Wow so I shouldn't have to use any clear! Nice
