Go Back   Telecaster Guitar Forum > Other Discussion Forums > Other Guitars, other instruments
Other Guitars, other instruments Use this forum to discuss all guitars and other instruments that are not Teles or Strats -- Fender, Gibson, PRS, you name it. If it's a Tele or a Strat see the appropriate Tele and Strat Forums here.
Old May 26th, 2012, 11:56 PM   #1 (permalink)
otterhound's Avatar
Gibson headstocks
Has Gibson ever used hide glue for the scarf joint that attaches their headstocks ?
otterhound is offline   Reply With Quote
Old May 26th, 2012, 11:58 PM   #2 (permalink)
63dot's Avatar
The vast majority of Gibson headstocks are one piece. I had a very cheap Gibson Sonex 180 Custom and there are other cheap ones like Marauder and Challenger and it wouldn't have made sense to waste wood and make one piece headstocks. I can't tell since it was under a ton of candy apple red paint. The scarf joint, while not very common, is still a good way to go and while not one piece of wood, it doesn't make the neck weaker but probably would add some strength. It's more of a bragging point to use one piece of wood, just as it is a one piece tele body over two or three pieces.
63dot is offline   Reply With Quote
Old May 27th, 2012, 12:26 AM   #3 (permalink)
otterhound's Avatar
If the vast majority are one piece necks , why all the drama concerning Gibson necks and the scarf joint that attaches the headstock to the neck ?
Old May 27th, 2012, 12:39 AM   #4 (permalink)
Turtleface's Avatar
I think most the dram lies in the inherent weakness of the angled back headstock. I just received my first Les Paul, and even Gibson acknowledges it in the product manual. Goes so far as to let you know standing the case on end is a bad idea, as even that has a decent chance of breaking the headstock.
Turtleface is offline   Reply With Quote
Old May 27th, 2012, 01:39 AM   #5 (permalink)
Nick JD's Avatar
They break because they don't use a scarf joint.
I recall gibson stopped using hide glue some time in the 60s. Gil will know.
Old May 27th, 2012, 03:58 AM   #6 (permalink)
Please post a pic of a Gibson neck with a scarf joint. I have never seen one.
Side note:The volute at the base of the headstock on one piece neck C F Martin guitars (Style 28 and above) is a stylistic tip of the hat to an inset headstock join from many,many years past.
"Life is mostly Froth and Bubble" Adam Lindsay Gordon
chezdeluxe is offline   Reply With Quote
Old May 27th, 2012, 10:44 AM   #7 (permalink)
63dot's Avatar
I don't think the Gibsons are so weak that they break in the case, but dropping them is a totally bad thing. I have been lucky with ten Gibsons over many years. I don't know how many of us have enough space, with multiple guitars, to lay them all down. There must be tons of Gibsons standing up in cases in closets and we would have definitely heard about lack of protection if that were the case.
In every case I have heard about a broken Gibson was because it fell off the player and hit the floor either on the front of the headstock or the back of the headstock first. The biggest issue more than the angle is the large amount of wood taken out near the nut for the truss rod leaving very little wood left to support the tension of the strings.
Old May 27th, 2012, 11:02 AM   #8 (permalink)
63dot's Avatar
Even with no truss rod channel leaving more wood on front and volute adding more wood on back, brittle mahogany with angled headstock is a combination which can break. (but last three pictures show that even this can be fixed).
That type of breakage at headstock on a maple neck Fender seems almost as likely as a confirmed UFO landing on the White House lawn.
ID:	128855   Click image for larger version
ID:	128856   Click image for larger version
ID:	128858   Click image for larger version
Old May 28th, 2012, 10:08 AM   #9 (permalink)
If a Gibson has a scarf joint where the headstock is attached, it's not a Gibson. Does Epiphone use scarf joints? Regardless, it's not hide glue.
Don't let them steal your joy.
daddyopapa is offline   Reply With Quote
Old May 28th, 2012, 11:47 AM   #10 (permalink)
charlie chitlin's Avatar
Epiphone uses scarf joints
Dig yo'self
http://blueplatespecials.net/
charlie chitlin is offline   Reply With Quote
Old May 28th, 2012, 05:28 PM   #11 (permalink)
nadzab's Avatar
I dropped my LP right on the neck once. Hit my amp, it was a drop of about 3 feet, and I was afraid to look. Guess what, the neck was dented, but there was no catastrophic failure.
My SG Classic doesn't have a scarf joint, but it does have "ears" on the headstock, which I find kind of interesting.
nadzab is offline   Reply With Quote
Old May 28th, 2012, 05:43 PM   #12 (permalink)
The Challenger, Marauder and Sonex have 3 piece necks (plus wings) but they do not have a scarf joint.
J.E.M. is offline   Reply With Quote
Old May 28th, 2012, 07:46 PM   #13 (permalink)
63dot's Avatar
Three piece necks? Wow.
I couldn't tell and when I looked at it, I didn't see any seams running down the neck like on my three piece neck Aria Pro II. Anyway, kudos to Gibson for pulling off a three piece neck without showing through the finish. My Sonex was pretty beat up, too and it had a great sound. I miss that guitar. It also had a great sounding coil tap which didn't depress the volume too much when I went into single coil mode.
Old May 28th, 2012, 08:58 PM   #14 (permalink)
paratus's Avatar
I had a 73 LP Deluxe, it had a three piece neck, it was pretty easy to see the seams through the finish.
Semper Paratus
paratus is offline   Reply With Quote
Old May 29th, 2012, 08:50 AM   #15 (permalink)
3 piece
1983 Challenger, 3 piece plus wings, no scarf joint and a work of art to play, it's a regular LP neck but in maple, tough as nails...
Old May 29th, 2012, 10:58 AM   #16 (permalink)
Abu Twangy's Avatar
Some examples:
My '70 GibsonSG 200 had a one piece maple neck with wings
'92 Gibson Les Paul definitely had a one piece mahogany neck with wings.
'04 Epi Dot had a scarf joint maple neck with a three piece headstock
'09 Epi Dot had a one piece mahogany neck with a hidden scarf joint and athree piece built up headstock
'03 Epi Joe Pass had a three piece maple neck with glued on maple wings
Abu Twangy is offline   Reply With Quote
Old May 29th, 2012, 11:20 AM   #17 (permalink)
Flemtone's Avatar
63DOT - Unfortunately, I found out the hard way that they can break even in the case.
My 74 Deluxe fell over in the case. It was being kept by a friend, I wasn't there so I don't know how hard it hit the floor, but it still broke.
They did the right thing by me, though. Got it professionally repaired immediately, and now you almost have to know it's there to see the crack.
Flemtone is offline   Reply With Quote
