Originally Posted by Guitartom_ca
how do i wire the toggle switch so that i can make only one coil in the neck and one coil in the bridge work?
thanks
According to the SD wiring diagram from the website the Red & White wires which are joined need to be shorted to ground via a switch, "toggle or push/ pull" in order to operate in single coil mode. I have a Tele Plus control plate which has a mini toggle between the pots that I will be using to split the GFS Lil Puncher XLs I plan on using on my build.
Hope that helps
