Pup replacement in archtop (ntc)
I've replace pups in Teles and Strats with good success. Any pointers, dos/donts on replacing pups in ES-333 (or similar archtop). I tried post on Gibson page with no response, figured the most knowledeable folks are TDPRI. Tx in advance
PUPs only or electronics too?
I've seen (and done on a few beaters) splices; 'nother words the original leads to the switch and pots is in tact and the new PUPs are soldered to the old wire. NOT THE BEST METHOD FOR A NICE NEW GIBSON (I had to scream that before I got flamed!), but it could be done.
All of us contain Music & Truth, but most of us can't get it out. Mark Twain |
Yup, cutting the existing wires and splicing the new ones in is pretty tacky. The better method is to loosen the pots, pull them through the pickup holes, and rebuild the harness on the outside. The trick is to tie strings onto the pots before you pull them through, so you can put the whole thing back together without being driven to violence and mayhem.
Good advice. Also, you can use a length of surgical tubing over the pot handles to pull them back thru the holes.
One thing I found out the hard way is that pickup rings can vary slightly, so make sure the holes line up. If they dont, make sure you predrill new screw holes. I cracked the urethane finish around on one of my cheapies by not drilling new holes. And also there is now a line in the finish from the old pickup surrounds being slightly larger. Eek. |
Dental tools...
I have used the same mirror my dentist uses for looking at my teeth. Very handy for having a looksy inside. I have even used dental floss to retrieve the pup switch etc.
