#41 (permalink) | |
If you follow my threads above, you will notice that I changed my opinion, after cafrefully considering the details. As I mentioned in my last post above...different capacitor construction results to different parasitic elements of the cap...since a real cap is more than just an ideal capacitance value. Whether or not you can hear sonic differences from the subtle parasitic differences is the question, and if you do, then who is to say that you can't? |
#42 (permalink) | |
...I felt the same as you, I believed from past posts that changing a cap would not make a difference, but after hearing it for my self I have to admit I was wrong When Don Mare tests caps he uses alligator clips and tests over a hundred different caps at a time and he has found the good caps and he buys them up off of eBay I was lucky that I went to him and heard the difference myself. Its like comparing one cap that sounds like cardboard and another cap has the sonic quality of a pipe organ |
#43 (permalink) | |
My opinion change is based on carefully reviewing technical details. I have no idea if I can actually hear any difference. The experiment that Don Mare does is interesting but it doesn't reveal WHY the sonic differences exist. It's not a controlled experiement. The end result is effective though...if you like what you hear...then most folks won't care why. Although...if you did really know why...it might focus your search and save you $ from plunking down big $ for exotic caps. |
#44 (permalink) | |
Somehow Mr. Mare always comes up in your posts :) As far as his "testing"... is he testing them for their value of capacitance? What else in the world is he testing and how do you test for anything else? I suspect he's cherry picking exact values that are nearly identical. Tolerances what they are, no two .047 caps will actually be exactly the same (nor exactly .047 usually). Also, poor BrianF shouldn't have to keep repeating himself - what in particular he is talking about he has doubts can be heard with the naked ear. Certainly a cap of same measured value in a guitar will NOT be "night and day" or "cardboard vs pipe organ" - it wouldn't be that drastic between materials - in a guitar (especially with the voltages present). If it is different, it would be arguable if it could even be heard by the human ear.
- 3 Gibsons, 5 Teles, assorted other guitars, about a dozen amps, about two dozen pedals, a Smith & Wesson SW40VE, & a .40 SIG Sauer P226R = too many toys, no money, carpal tunnel, and a serious hearing problem. |
#45 (permalink) | |
"I feel that it is healthier to look out at the world through a window than through a mirror. Otherwise, all you see is yourself and whatever is behind you." - Bill Withers |
#46 (permalink) | |
I live close to Don and he is a friend of mine I am no expert but I do know tone |
#47 (permalink) |
Don is probably also cherry picking caps that work specifically for his winds.
Not only do different cap values alter the tones, but the specifics of the pickup used will alter things drastically, sometimes requiring a very different cap value. I have a Harmonic Design S90 that sounds markedly darker with the same value tone cap as used on other pickups. This is why Scott himself oftentimes recommended that S90 users try a TBX, and possibly even change pot values. I suspect Don's pickups are not heavily potted, either. Such a pickup would probably require a heavier cap value. Once you start the "this cap sounds best with this pickup" thing, it gets way too subjective. All of my guitars currently have ceramics - some replaced pricey (80 cent polys - HEE!) caps, and they sound the same (to me). Actually, when I go to grab another tone cap for a guitar, I go to my 'scrap box' of caps from amp parts. I've actually tried 150's and a whole mess of other mentioned caps above. I usually spec them out w/my Fluke, and go for no variance beyond 70 pF. I could probably go up to variances as much as 200 pF, and still not hear a difference. Apparently, my hearing is not as sensitive. And I'm glad for it.
#48 (permalink) | |
#49 (permalink) |
Nice Work
Fellas: this has been a good discussion.
Like many things, it seems, perhaps, to boil down to a debate between "faith in things unseen" and "cold, hard facts"--and that is a debate that's been raging for lo these many centuries, and continues, sadly and tragically, today in many serious areas that have nothing to do with Telecasters. The good thing is, if none of this makes much difference, a goofball like me can't screw up too badly, and if these things do make some kind of (merely subjective?) difference, then bully for those Dr. Frankensteins who try to cobble bits and pieces to create their perfect monster. To each his fetish. Anyway: thanks for the full-throated defenses of your positions.
" . . . someone to do your dirty work . . ." |
#50 (permalink) | |
This is why these kinds of threads frustrate me to no end. Then claims of tests and scoping waveforms and all of this other stuff pop up. I can't count on two hands and two feet how many amps I've built or repaired and how many guitars I've rewired over the years. Forget about how a capacitor functions in conjunction with a resistor (a pot) in a guitar, this magic $30 cap sounds like "night and day" compared to... So I say, just use whatever caps you like or think sounds best - whether its in your head or not... I'm thoroughly done discussing this topic (especially seeing as how a search can pull up piles on this topic that seems to pop up monthly). Be happy, use what you like.
#51 (permalink) | |
Of course, I didn't fiddle with pot values, caps, adding a TBX, changing the heights on the polepieces, etc. - all of which Scott told me to try. I basically like to drop in a pickup, tweak the height, and maybe swap out a cap for another value. I'm in love with 250K pots because of the gradual taper. 500K and up do drastic changes, too fast. Now I've got/modified a Marshall, and will be trying the S90 again and some point with that amp. To me, the S90 does not sound like a P90, or a 'Tele pickup on steroids' as was claimed. It's more of a flatter response, with more output. I like to think of it as best suited for an overdriven amp - good for AC/DC and the like.
#52 (permalink) | |
does Scott offer rewinds |
#53 (permalink) |
I don't think so.
And like I said, his take on this is basically 'operator error,' because I didn't fiddle with pots, caps, polepieces, etc. Can't really fault him on that, though. It's a radically different design. It makes sense that you have to tweak everything around it to get it to work. And a lot of guys love it. There's simply no disputing that. I think the best Harmonic Design pickup is the Z90. Unfortunately, it's not a Tele pickup. There's also a bit of a wait with his stuff, and I don't like waiting. The S90 was a gift, so it was an exception. I've found that the biggest determinants with most pickups tends to be pickup height and string gauge. Most of these can be dialed in to make most pickups work. Occaisionally, you'll get one that has a frequency response that you cannot get around. But fiddle with the 2 things above, along with adjusting the amp and using the tone control, and it's all good.
#55 (permalink) | |
You are great, thanks for starting this tread your goal was to help with peoples tone and that's a wonderful thing!!!... Last edited by JamonHamon; July 11th, 2007 at 04:38 AM. Reason: spelling |
#56 (permalink) | |
#57 (permalink) |
![]() Poster Extraordinaire
Hehehehehehe - it's interesting to see how little people understand about guitar circuit passive tone pot caps (NOT to be confused with amp caps). All that matters about guitar non-electrolytic caps is the value and the build. You can talk a blue streak about $40 non-electrolytic caps but for my opinion, no one can accurately tell the tone modifying difference 'tween that over rated booteek cap and a 65 cent RS green weenie. Geez, passive tone pots are just sonic mufflers anyway, ...
#58 (permalink) | |
Undertsanding the mechanics of what a tone cap is and how it interacts in a passive low voltage guitar scenario has been brushed aside... what was that old '80s Reagan era phrase? Voodoo Economics... there's gotta be a guitar oriented phrase for that here...
#59 (permalink) |
Tear Down That Wall
Voodoo Tone-o-metrics?
Voodoo Toneology? Voodoo Lutherie? Voodoo Nitrocellulosity? Obsessive/Compulsive Pickup Disorder? Adult On-set Obsessive Attention to Irrelevant Detail Disorder (AOOAIDD) Manic Depression?
#60 (permalink) |
HAHAHAHA I think we all suffer from this one. I know I do :(
