Old April 19th, 2007, 06:17 AM   #1 (permalink)
Texas Special to midy - replacement sugg.
Hi,
I have a texas special in CIJ telecaster. I like the fullness ... especial the neck pickup, but sometimes the pronounced mids are just to strong - sometimes when I close the tone down the highs (kind of jazzy sound) just do not cut through. Can someone suggest replacement pickups ... not so different - just with just a bit less mid output. I was thinking of Harmonic Design Vintage Plus set?
kaketz is offline   Reply With Quote
Old April 19th, 2007, 08:22 AM   #2 (permalink)
fezz parka's Avatar
Lower the pickups a little.
Old April 19th, 2007, 08:13 PM   #3 (permalink)
OaklandA's Avatar
+1
Seriously, the Texas Specials seem really sensitive to height adjustment more so than other pups.
________________________
_________________
___________
That's what she said.
OaklandA is offline   Reply With Quote
Old April 19th, 2007, 08:54 PM   #4 (permalink)
Daddydex's Avatar
Originally Posted by OaklandA View Post
+1
Yep, I just did it on mine. Whole different guitar.
Dan
Teles are like Mr. Potato head
Daddydex is online now   Reply With Quote
Old April 20th, 2007, 01:18 AM   #5 (permalink)
Thank you. I will try ... Any suggestions maybe ... how far did you guys lower them - what is the distance from freted high E to top of the neck cover?
Old April 20th, 2007, 07:56 AM   #6 (permalink)
fezz parka's Avatar
Use you ears, not a ruler. With the neck pickup start at being flush with the guard.
This doesn't really show the height, but this is where the bridge sounds good to me. I also try to angle the bridge pickup so that it is lower on the bass side than the treble side, it kind of evens the stagger out a little and sounds balanced ( at least balanced enough)...
Old April 20th, 2007, 08:14 AM   #7 (permalink)
thanks for your effort fezz! I think my pups are lower than that! ;)
Old April 21st, 2007, 04:36 PM   #8 (permalink)
If adjustment dosen't cure your problem. try a set of Van Zandt True vintage pups. I replaced a set of Texas specials with the Van Zandts and was very happy with the results.
Big Daddy is offline   Reply With Quote
vB code is On
Forums Directory
