Old March 18th, 2007, 07:00 PM   #1 (permalink)
austintele's Avatar
fender 60's ri pickups
Does anybody know if the 59 esquire, 60 and 63 telecaster all use the same pickup(s); basicly interchangeable?
Is the 62 AV ri the same pickup as well?
austintele is offline   Reply With Quote
Old March 19th, 2007, 08:42 AM   #2 (permalink)
GTO
I believe the CS 59 Esquire and the CS '63 Tele share the same bridge pup. The only '60' Tele I know of is the Classic series, and like the AV '62 they don't use CS pickups, but have an alternative specification. They are all interchangeable in that with a small amount of soldering they just 'slot in'.
GTO is offline   Reply With Quote
Old March 19th, 2007, 09:24 AM   #3 (permalink)
yegbert's Avatar
I'm not familiar with CS models and what pickups they have.
The Classic Series '60s Tele has a bridge pickup wound around 6.4k; its polepieces are staggered and are not beveled on their tops; it has plastic/vinyl (not cloth) insulated leads, and has plastic top/bottom plates for a framework without any metal baseplate. Fender's parts list identifies the part number as the same pickup used on the Classic Series '50s Tele and '50s Esquire, and in an earlier version of the Hwy 1 Tele; however all those had a flatpole bridge pickup. My theory is, that's a typo and the '60s bridge pup is the same one that's used in the Classic Series '69 Thinline and '72 Custom.
I like the Classic Series pickups. I've figured out how to add a baseplate in an easily reversible way and I keep trying them with and without. I think I like them better with a baseplate.
The AV '62 Custom bridge pickup polepieces are staggered with beveled tops. It has cloth insulated leads, fibrous top/bottom framework and a copper plated metal baseplate. Darrell loves his. I have one on order from my local Fender dealer to try.
Old March 19th, 2007, 01:39 PM   #4 (permalink)
tonfarbe's Avatar
Anyone compared the Classic 60s Tele bridge pickup to the AV 62 RI?
I know about the construction differences, but what about their sound?
tonfarbe is offline   Reply With Quote
Old March 19th, 2007, 02:15 PM   #5 (permalink)
Kinda
I have tried the MIM 69 ri and the MIM 50's ri, and I own a USA 62 ri bridge pup. I think the MIM 69 ri and the MIM 60's ri are the same pup. IE...it is the same as the 50's ri, but with staggard poles.
The USA 62ri bridge pup is the finest pup I have ever owned. It has loads of twang. To the point where the layman might say it is "microphonic".
I found the MIM pups mentioned above to be OK, but the reality is, they are not even in the same class as the CS USA 62ri pup. This pup is a CS shop pup, and it is as good a CS pup as you can find. It is special, and it is worth the coin.
"Yeap, I like the American Standard Telecaster, I can even live with one a them PCB amps, and I even use one a them mul-tie-effects things too."
Darrell is offline   Reply With Quote
Old March 19th, 2007, 04:02 PM   #6 (permalink)
austintele's Avatar
I actually meant the 60 telecaster custom that the custom shop made recently.
here's an example
http://www.gbase.com/Stores/Gear/Gea...px?Item=849592
the reason I'm asking is that i have a line on a 62 AV bridge pickup and want to get it as a backup for my custom shop tele. I think it's pretty much the same as the CS ones without the CS sticker.
Thanks y'all
Old March 20th, 2007, 09:58 AM   #7 (permalink)
There is no CS sticker on the USA 62 ri pup that I got from guitarpartsresource. I don't really care...I got what I was looking for and then some.
For that matter, it didn't even come in a box. These pups are not sold individually, and packaged. They must have some kind of back door relationship with Fender. That is all I can determine.
By the way, I went to Fullers just a few months ago, and that isn't the only 60's CS tele they have. I saw about 6 or more there. Arguably the best set of 60's CS Tele's I have ever seen in one place. Just stunning. I was in awe.
The pup I have is very unique from any that I have seen before, and it is visibly different from any discussed in this thread. The pole pieces are staggard and BEVELLED.
Old March 20th, 2007, 05:01 PM   #8 (permalink)
GTO
here's an example
austintele no, the one you are talking about won't be an CS '62 pickup, the Custom Shop do not use pickups from other lines. Neither do they make a '62 reissue' pup as such. And the Custom Shop do not stick stickers on the bottoms of the pups on their own guitars, they only ever stick them on the 'aftermarket' pups they sell in sets. From what you describe it sounds like you have a regular AV '62 pup.
Old April 21st, 2007, 04:11 PM   #9 (permalink)
Caper's Avatar
Before adding a grounded baseplate a 60's r.i. bridge pickup measured 6.4 k on my meter and after the plate was grounded it measured 6.86 k.
Caper is offline   Reply With Quote
vB code is On
Forums Directory
