Old September 8th, 2006, 04:17 PM   #1 (permalink)
telecaster69's Avatar
installed noiseless pickups...now..noisier?
I took out the Hot Vintage pickups in my telecaster and put in Noiseless ones..but now I"m getting a worse hum and buzz..it seems to go away when I touch the knobs or cable or put my hands on the strings....what's the deal? is something not grounded right?
Taylor 310 Acoustic with LR Baggs ibeam. Gold Tuners with Ebony buttons
2004 Telecaster w/hotrails, lckng tuners
Fender Powerchorus Amp 2x12"
Aphex Aural Exciter pedal
HBE Big D distortion pedal.
telecaster69 is offline   Reply With Quote
Old September 8th, 2006, 04:52 PM   #2 (permalink)
yerffej's Avatar
sounds like your string ground is not properly connected. if the bridge pickup has a metal baseplate, it is likely connected to ground already. double check that first
yerffej is offline   Reply With Quote
Old September 8th, 2006, 09:51 PM   #3 (permalink)
OK...I"ll pull it apart tonight...what should I look for....check the baseplate of the bridge pick up for a ground wire on the bottom?
Old September 8th, 2006, 10:17 PM   #4 (permalink)
I pulled the bridge pickup off and it does not have a metal base. no ground wire at all...how do I fix this problem
Old September 8th, 2006, 10:20 PM   #5 (permalink)
Add a wire, solder it to the volume or tone pot, and strip the wire on the other end and put it in one of the bridge mounting holes. Strip the wire on that end enough so it touches the bridge, and stays in the hole.
RockinCarl is offline   Reply With Quote
Old September 8th, 2006, 10:23 PM   #6 (permalink)
which bridge hole are you referring too...the holes that mount the pickup to the bridge or the ones that hold the bridge to the body...
Old September 8th, 2006, 10:43 PM   #7 (permalink)
bobthecanadian's Avatar
i found that this site helped.
guitarnuts.com
It don't mean a thang if it ain't got that TWANG!!!
bobthecanadian is offline   Reply With Quote
Old September 9th, 2006, 05:56 AM   #8 (permalink)
Whoops! Sorry.
I was talking about the bridge/body hole... it works, and its the way I do it when I need it, but I'm sure other people have other methods for it.
Old September 9th, 2006, 03:08 PM   #9 (permalink)
I got it grounded and it seems like most of the hum is gone when I directly run it into the amp. if I use a distortion box...then the hum comes back until I touch the strings.
Old September 9th, 2006, 03:27 PM   #10 (permalink)
Theres nothing you can do about that- its like that with every guitar, unfortuently. If you listen closely, the hum is there even if you directly run in to the amp, its just not as noticable.
