Old July 29th, 2003, 04:32 PM   #1 (permalink)
Blown away by a 9 dollar pickup
Ok, I have two tele's. One a poplar body with a SD Hot Rythym in the neck (runs about 9.5 DC). The other is a alder body tele with a stock pick up from a MIM standard tele.
Why is the stock MIM pickup darker, woodier, and bigger sounding, almost humbucker'esc (I am not say more powerful) than the SD pickup, which I would imagine has many more winds. And we are not talking a little bit of a difference, but a really big difference.
Is it the wood of the guitar or are these MIM stock pickups wound up a lot more that I am led to beleive. Any clarification would help.
Is it possible that the best neck pick up that I own is a 9 dollar MIM standard? I wish someone would have beat me over the head with that news a few years ago...I could have saved some cash.
I am still hanging on to the SD...it's not bad, just brighter and less smooth. Besides I really like the other SD pu's that I have. And I like the company.
"Yeap, I like the American Standard Telecaster, I can even live with one a them PCB amps, and I even use one a them mul-tie-effects things too."
Darrell is offline   Reply With Quote
Old July 29th, 2003, 05:22 PM   #2 (permalink)
Mark Davis's Avatar
I bought 5 different expensive boutique neck pickups before I realized the stock neck pickup in my 50's Classic MIM Tele sounded better than all of them.
Old July 29th, 2003, 06:38 PM   #3 (permalink)
rebelern's Avatar
I Agree,about that MIM Stock Neck Pickup, I was told, it's
fitted to the Classic 50's/60's/& 69 Thinline,and now it's Stock,on the MIA/Highway-1, Which I Bought recently, and so far, I'm Really Pleased with the Sound/Tone, and the Bridge Pickup's, good also,and it was Stock on
the MIM/50&60's, but not the 69 Thinline.
Ernie.
rebelern is offline   Reply With Quote
Old July 29th, 2003, 06:54 PM   #4 (permalink)
This is how dark it is
To get the same sweet darkness, that is in the humbucker range...
MIM stock w/ tone all the way UP =
SD HOT neck pu, with the tone turned all the way DOWN.
That is REEL dark.
This makes a wonderful jazzy thing WITH range, because it will get a lot darker. Jazz, western swing, perfect.
Old July 31st, 2003, 11:09 AM   #5 (permalink)
A: What a pickup sounds like depends a lot on the guitar it's in
B: pickups represent the cutting edge technology of about 1928--some magnets and some wire. No reason why a cheap pickp can't be great (see point A)
maxvintage is offline   Reply With Quote
Old July 31st, 2003, 12:54 PM   #6 (permalink)
Well
If you have an alder tele...try just the plain ole MIM neck. Sure, it doesn't sound like much at room volume, but just add a little more volume, some magical stuff starts to happen. You probably won't be able to put the guitar down after that.
I played with it for about 2 hours last night. It is truly special.
You are probably thinking, why didn't leave the other pickup in the guitar (AS neck). I had put a new SD Bridge in the guitar. For them to work together, I had to cut the ground on a neck pickup. I didn't want to cut the AS neck incase I wanted to put it back in with a Fender wind. Besides, there was something special about the darkness that caused me to experiment by putting this pu in.
I am glad I did.
Old July 31st, 2003, 02:36 PM   #7 (permalink)
MRK
I'm new to replacing pickups. Darrell, what do you mean you have to cut the ground on the neck pickup? Does all SD bridge pups require that?
Thanks.
MRK is offline   Reply With Quote
Old July 31st, 2003, 02:52 PM   #8 (permalink)
Jef
Jef's Avatar
The neg. wire of tele pickups is grounded to the elevator plate on the bridge pickup / resp. the cover of the neck pickup. SD pickups happen to be out of phase with stock Fender pickups. This problem only occurs when combining both brands on the same guitar and can easily be solved by reversing the wires, BUT, you'll have to cut the ground and connect it to the other wire or run a separate ground wire.
By the way, I really like the Tex Mex neck pickup that came stock with my MIM Nashville.
Jef
Jef is offline   Reply With Quote
Old July 31st, 2003, 02:53 PM   #9 (permalink)
Scotland's Avatar
Agree
Best neck pickup around in my opinion. Do they sell them on their own?
Old July 31st, 2003, 02:55 PM   #10 (permalink)
All SD's
are wound the opposite of Fender, and other mfg'ers. So if you use one of these IFender or other mfg) with an SD, you will have to cut the ground, and use the black wire as the power wire for them to work together properly.
I didn't want to cut the my AS neck pu because I may replace it in the guitar with another Fender one day (thinking it was the better pu). So I took the little cheapy MIM stock neck pup I had in the drawer and cut the ground on it, ran the black wire to power, so it would work with the SD bridge pu that I bought. Lucky for me, I have a neck pu that is far better than I expected.
Old July 31st, 2003, 03:20 PM   #11 (permalink)
MRK
Thanks for the explanation but I still don't get it. . .I need some advice.
I recently ordered a SD Broadcaster bridge and DiMarzio Twang King neck pickups. So in order to get them to work together, I have to connect the SD's black wire to the 3-way selector switch and solder the other wire to the pot?
Thanks.
Old July 31st, 2003, 03:56 PM   #12 (permalink)
Ok..
Lets say you wire the two up straight out of the box. When you put the switch in the mid position, they will be out of phase. Which means when you raise the volume, in the two position, the guitar won't get any louder, because one pickup is going to cancel the other out.
To fix this, one of the two pickups will have to be modified. I usually modify the neck pu. To do that you have to cut the little ground wire on the back of the pickup. Then run the black to hot and white to ground (backwards). Then the two will work right in the mid position.
Old August 3rd, 2003, 12:50 PM   #13 (permalink)
Cheapos...
In my '58 I've got Lindy Rewinds and they're amazing,
haunting with a brass slide. In my Classic 50's MIM the
pickups are close.....very close.....very. Let's face a reality here the "real stuff" for the most part was made
by Mexicans, (that "TG" on the neck don't mean "Tim Gilhooley") So it only stands to reason that the folks
South Of The Border are on a mission to show the world
they got what it takes to build more than a merely good guitar- yep these people are making their stuff with Soul.
Two weeks after I brought home my MIM I had a chance to get a Mary Kay for 10% over cost (great deal),
I passed.
Somebody Loan Me A Dime
stantheman is offline   Reply With Quote
Old August 4th, 2003, 02:49 PM   #14 (permalink)
lewis's Avatar
A Fernandes bridge p/u...
...just kills the std. bridge p/u in my MIA '62ri.
lewis is offline   Reply With Quote
vB code is On
Forums Directory
