fundraiser
Old March 19th, 2006, 06:33 PM   #1 (permalink)
Pick up ID - MIM vs. American Standard
Ok, I want to put my stock AS pick up back in for a while. I have two pickups, and I don't know which one is the MIM, or the AS. Neither has a base plate.
Pickup one - Has a screw in the back, serial number 048610 on the back.
Pickup two - No serial number, no screw in the back, and has some vintagy texture to the surface of it, grounding ring on the black lead as if it is grounded to the guitar.
They both have yellow and black leads.
Which one is AS?
I think it is pickup two...but I thought the AS had a screw in the back and a serial number.
"Yeap, I like the American Standard Telecaster, I can even live with one a them PCB amps, and I even use one a them mul-tie-effects things too."
Darrell is offline   Reply With Quote
Old March 19th, 2006, 07:08 PM   #2 (permalink)
Caper's Avatar
I've had MIM and US Teles both had the same serial #'s on the bobbins. It's been a while since I had the MIM so I can't remember if they had the philips head screw on the bottom or not, the American Series have the screw on the bottom.
Caper is offline   Reply With Quote
Old March 19th, 2006, 07:15 PM   #3 (permalink)
red57strat's Avatar
The part numbers are available on Fender's website.
Don
red57strat is offline   Reply With Quote
Old March 19th, 2006, 07:50 PM   #4 (permalink)
Mark Davis's Avatar
0050890000 neck am std
0050888000 bridge am std
0041620000 neck mim std
0029044000 bridge mim std
Old March 19th, 2006, 08:00 PM   #5 (permalink)
This is good information
but none of these numbers are on either bridge pickup. I have the stock neck pickup in the AS. I am just trying to figure out which bridge pickup is the American Standard, so I can put it back in.
Old March 19th, 2006, 09:21 PM   #6 (permalink)
yegbert's Avatar
door number two
The flatpole MIM pickups which are part number 005-5216-000 and Fender puts in the Classic '50s Tele and Esquire and the Hwy 1; the ones I've seen anyway; have 048610 molded into the bottom of the plastic base, and have two philips head screws screwed into the bottom, one in between the A and D polepieces and one in between the G and B polipieces. The black parts are all plastic and have smooth, non textured surfaces. They have a blue ground lead and a yellow hot lead.
Sometimes this pickup will have the non-zero digits of the part number handwritten on the bottom, e.g. 55216.
I think I've read here that the same plastic bottoms with the 048610, were found the MIM Standard bridge pickups; and those I think had different color wires than the "55216".
Was your MIM pickup from an MIM Standard? My guess is that your second one is the Am Std.
Old March 19th, 2006, 09:36 PM   #7 (permalink)
yeg
my other tele is an MIM standard
Old March 19th, 2006, 11:26 PM   #8 (permalink)
Thanks guys
Looks like number 2 was correct. I can tell, it's very bright. Thanks for the help. I only had one set of strings on me.
My MIM standard pup was not bright.
