Tele buy-blind pickup suggestion?
Dear y'all,
I am completely overwhelmed by the many replacement pickup options available. I also don't have the possibility to test drive any (there are only smaller dealers in my area that don't stock such stuff). What pickups would you suggest for traditional Blues, bluesy Jazz, Soul, Funk (no Rock or Country)? Which pickups can be easily recommended for such a buy-blind purchase? (On Harmony-Central, most products from Harmonic Design, Kinman, Fralin, Torres Engineering, SD, Rio Grande, Van Zandt, etc. get great reviews. So should I just randomly choose one?) Very best wishes -Peter- |
| Sponsored Links |
Peter, you can get some ideas here or from other experienced players, but ultimately you'll have to judge for yourself what you like, and there's no substitute for putting those pickups in your guitar and playing them with your hands through your amp. Only then will you get a clear reading. What I've done is to buy a bunch of pickups over time USED, then resell the ones I don't want, usually at about the same prices. In my case, I ended up with Bardens in my 52 reissue, and those are absolutely the best pickups for what I needed, but they may or may not fit you.
You could get a bit more focused help here if you would tell us what guitar you've got now, what pickups are in it, what kind of strings and bridge it's got, what amp you use, and some recorded songs we know that have a tone you like. |
#4 (permalink) | |
Joel
It takes a whole lot of liquor to like her but when I'm liquored up I like her just fine |
Suhr
There are so many pup's out there it will drive you crazy (or buying them for the next couple of years). If you like twangy on the bridge without getting shrill sounding and jazzy/bluesy on the neck pu, try some Suhrs. Little talked about but great value and sound. I like them a lot.
PS John Suhr used to work for Fender. He knows his business. |
#6 (permalink) | |
Dear y'all,
many thanks for the suggestions. Quote:
The pickups are stock (single coil) pickups. I bought the guitar used (but in a new condition) a few months ago from a friend who wanted to learn to play guitar back then but ultimately didn't. I am currently using 009-042 Fender 150 strings. It has a bridge with 6 saddles. I use a Flextone 3 amp (I mostly use the Fender Twin Reverb, Deluxe Reverb or Roland JC-120 models). As for the guitarists: I love the Memphis sound so I dig Steve Cropper. Johnny Guitar Watson's early sides for Modern (Hot Little Mama, Too Tired, etc.). Albert Collins is one of a kind. Then there are current cats like Kid Ramos, Duke Robillard, Ronnie Earl, Kenny Blue Ray, who all have killer tone. I would have to check the CD liner notes for the song titles that feature a Tele, but I don't have them here right now. Very best wishes -Peter- |
Gotta say, I am in the middle of analyzing the results of a pickup change I just made in my Tele (ash/maple) and found the Rio Grande Big Bottom set got me immediately into Albert Collins tonal territory. Fender .009-.042 bullet set, Marshall JCM 800 1x12" 50-Watt Lead combo, Fender large triangular heavy pick or fingers. I also use a cheap solid-state Washburn combo amp with about 15 watts and an 8-inch speaker, and it just sounded fabulous. Just got the Albert Collins Deluxe CD and this just gets there. The difference between this Rio set and Duncans Broadcaster set is the character of the neck pickup; the bridge seems very similar. Of course, the guitar will do a lot of other tones, depending on your knob-twisting. The Broadcasters are excellent, but the Rio neck pickup is less "restrained," if you will.
Some suggestions
Many, myself included, really like the SD Broadcaster. Even those who later went for something else in a bridge PU rate it as an excellent choice. It does everything well and mates with a Rio tallboy for a great combo. My other fave bridge PU is a Van Zandt flatpole. I really like Gibson P94s and mini HBs in the tele neck position, but that requires surgery.
I know this is the pickup forum . . .
. . . but the first thing I would do is screw on a vintage 3-saddle bridge with brass saddles -- did this to my test-bed tele and it improved it as a blues machine 100%. something funky about what this does to the sound of the note, a lot like johnny watson in the "three hours past midnite" era. under half an hour to do it, under $30 for the parts. good luck.
#10 (permalink) | |
Re: I know this is the pickup forum . . .
Unfortunately, my Japan Tele has 3 mounting holes under the saddles and is a toploader. So far I could only find bridges with the older 4 hole pattern and the string-through-body pattern. Cheers, -Peter- |
Hey Peter check out this link
I have the same MIJ bridge plate as you and have found a couple of replacements that might work. This one looks like a direct replacement (MM2112) and I have verified the measurements on my own guitar:
http://www.mightymite.com/bridges/fixed/index.html Another one that looks promising is here: http://mailboxmusic.zoovy.com/product/GBR_T2BK Hope this helps...
no better, just older |
