Old June 22nd, 2003, 05:51 PM   #1 (permalink)
Fender custom shop texas pickups
What do people think of these? do they work well in series at all? thinking of upgrading just my neck pickup to get a clearer higher output sound, is this a good idea or should I replace both pickups?
Cheers!
hazza is offline   Reply With Quote
Old June 23rd, 2003, 01:00 AM   #2 (permalink)
Kingpin's Avatar
Didn't work for me
I tried the Custom Shop Texas Tele PU in the neck position and couldn't wait to get it out. No matter how high or low I set it, I couldn't get the sound I was looking for. It is a high output PU, so in that sense it might work for you, but I wouldn't characterize the sound as "clear". It sounded muddy to my ears. If you want a PU with strong output and a clearer sound than the Tex. Spec, I would suggest a Fralin Blues Special or a Barden in the neck. Also, the Fender Original Vintage has a fairly strong output and is an inexpensive alternative. It's hard to make a suggestion without more information from you. What type of music do you play? What pickups do you have in already?
FREE BILL KIRCHEN!
Kingpin is offline   Reply With Quote
Old June 23rd, 2003, 08:34 AM   #3 (permalink)
JohnK24's Avatar
Re: Didn't work for me
I agree with his assessment of the Tx. neck pup...I pulled mine out 2 weeks ago...it was muddy, strong, but muddy. I put in a Rio Grande Muy Grande neck pup...excellent results (alder body, vintage bridge). Clear, strat like in tone and the power of a 'bucker.
I've also had the Fralin Blues Special neck pup in an ash tele, a great choice too...same idea, clear, strong, definition of notes (and more Fender mud).
JK
JohnK24 is offline   Reply With Quote
Old June 23rd, 2003, 08:52 AM   #4 (permalink)
I mostly play quite heavy grungy music along with some blues, my tele is a 90's US standard with stock PUs, although I am pleased with the bridge, I was looking for a similar sounding neck pickup to a Seymour '59, but in single coil form and would wok well with a 4 way.
Thanx
Old June 23rd, 2003, 08:53 AM   #5 (permalink)
Thanx
Old June 23rd, 2003, 10:16 AM   #6 (permalink)
John E's Avatar
I didn't care for the TX specials...
Originally Posted by hazza
I mostly play quite heavy grungy music along with some blues, my tele is a 90's US standard with stock PUs, although I am pleased with the bridge, I was looking for a similar sounding neck pickup to a Seymour '59, but in single coil form and would work well with a 4 way.
Thanx
The TX specials were OK, but not great... as far as a Duncan 59, I have not heard a single coil close to that one... I am a 95% of the time tele neck pickup player, I would say my style borders on Rock, blues, fusion, pop, etc., etc. If you have Real Player you can can stream one of the tunes I recorded with the Lawrence 280's(listed below) for the Rhythm parts... can't remember if I used it for the leads or not: http://www.hieroglyphmusic.com/audio/newcd/track06.ram
Here are my current fave neck pickups:
1) Fralin Blues Special - I have this wired just to the volume, no tone. Clear, strong, great pickup... I have this wired with a 4-way switch.
2) Bill Lawrence L-280 - This is a fat pickup, it's a humbucker that fits w/o mods into the tele slot (looks like a standard tele neck pup w/o the nickel cover) I currently use this with a q-filter.... this pickup will get you close to what you're looking for at a good price
3) Barden - I actually haven't used one in a while but I remember liking the neck pup and thinking it was similar but a little bit stronger than the Lawrence 280.
4) Van Zandt vintage flat pole - These are my next set, true single coil similar to the Fralin Blues specials, but I think the bridge sounds better... actually this is the best bridge pup I've ever heard
John E is offline   Reply With Quote
Old June 24th, 2003, 07:37 AM   #7 (permalink)
thanks for that, i think my next step is to do some research into some of the pickups mentioned, but just one more thing - does the Bill Lawrence work with a 4-way switch?
cheers again
hazza
Old June 24th, 2003, 07:38 AM   #8 (permalink)
cheers again
hazza
Old June 24th, 2003, 12:50 PM   #9 (permalink)
John E's Avatar
cheers again
hazza
The Lawrences can be wired into a 4way as far as I know... I know I've played Bardens with a 4 way also. I don't have my Lawrences wired that way as I have a Q-filter wired in as the tone control with a 3-way switch.
Old June 24th, 2003, 01:46 PM   #10 (permalink)
Tim Swartz's Avatar
The router is always an option.
Old June 29th, 2003, 09:50 PM   #11 (permalink)
TX Specials arent a magic bullet
I agree with everybody else.i tried the tx specials and i hate them with a passion,they may be ok for some people but for me i had to get them out the guitar in less than a week after they were in .i went with the duncan 5/2's both neck and bridge they both have worked and sound great to my ears anyways
TeleTwanger37 is offline   Reply With Quote
