noiseless pickup hum mystery!!!!!
Hi
Has anyone ever experienced anything like this with noiseless pickups....? I installed a set of vintage noiseless pickups in my tele this week and found that the bridge pickup still hums like a single coil. The neck pickup is deathly silent while the bridge seems to have that 60 cycle hum like my regular teles. I had a set of Dimarzio Area T's lying around and installed them...same issue, the bridge hums too while the front pickup is silent. The bridge plate is earthed and all is wired correctly. I've shown it to a guitar tech who is as dumbfounded as I am. Any thoughts? Cheers |
The wire going from the neck pickup to the electronics is a lot longer than the wires between the bridge pickup and the electronics. The longer wire, if not shielded (and it's usually not), is enough to pick up a little hum. It shouldn't have the hum of a single coil, though. If it's a dual coil pickup, or a stacked pickup, you may have one dead coil. You may also have wired it wrong, but I suppose you double checked all that.......
EDIT: just re-read your post and realized I read it backwards. It's the bridge pickup that's humming. Nevermind! It's gotta be either a defective pickup or a botched installation.
www.seattleguitarrepair.com |
There's actually a tiny little angry irishman in your bridge pickup screaming at you. Except because he's so tiny, all you're hearing is that hum.
... No?
Fatherless, motherless, born without skin; it spoke when it came into the world and never spoke again... What was it? |
Thanks guys. Yeah, checked all of that (even the Irishman, def free of Leprechauns etc)
I've just swapped the control plate out for another one including the output jack and leads, still got it with both noise cancelling bridge pups (Dimarzio and VN) Totally stumped and about to buy a les paul (only joking) |
Quick update, bizarrely I've now wired up an actual PAF Humbucker to the control plate (obviously not installed it under the strings to see if that hummed also.....and it does hum, like a piece of stilton thats been in sunlight for 72 hours. And still that neck pup is silent and sounds amazing :-/
What the....? |
what material is your bridge plate? I had hum with my Wilde L290TL when it was in a stamped steel bridge plate. When I changed back to a brass bridge, all hum disappeared. The steel distorted the magnetic field of the pickup enough to throw the humbucking balance between the coils off. A similar thing could be happening here.
I have a similar issue in my CIJ Tele Custom which has a DiMarzio Virtual Vintage in the bridge and Duncan Vintage Stack(is that the name?) in the neck. My tech basically said those pickups are not 100% noiseless if you're playing at any sort of higher volume or with pedals and that's that. Very far from a typical true single coil though. I've gotten pretty used to it and FWIW I am still very satisfied with the sound of the pickups and guitar. Good enough will have to do.
#11 (permalink) | |
![]() TDPRI Member
Noise-less pickups are great at cancelling hum, but all of that metal associated with the Tele bridge can make them susceptible to buzz. Try wiring it with only one path to ground from everything in the bridge cavity. I would suggest grounding everything to the bridge plate (pickup, shielding if there is any) and then running a single wire from the bridge plate to ground in the control cavity. And if you don't have shielding in the bridge cavity, it is a good idea to combat buzz. Also, make your wiring as clean and as short as you can and employ the twisted pair wherever possible. I can almost guarantee you the problem is not the pickups themselves. I'm still working through what is actually driving these kinds of issues, but I suspect it has something to do with the resistivity of that big hunk of bridge plate screwing with the ground potentials.
Affiliated with: Lawing Musical Products, LLC Inventor and designer of Zexcoil pickups www.zexcoil.com Last edited by Zexcoil; August 14th, 2012 at 06:25 PM. |
#12 (permalink) | |
![]() TDPRI Member
These are the kinds of responses that lead me to believe that the root cause is related to the resistivity of these relatively large chunks of metal that need to be grounded in this situation.
Affiliated with: Lawing Musical Products, LLC Inventor and designer of Zexcoil pickups www.zexcoil.com |
I feel sorry for you.I have the same pickups and the bridge pickup isnīt even grounded!(I forgot to do it and it doesnīt seem to make any difference!Have you tried to wire it to the output jack with nothing else connected to the jack?Tried it in another Tele? How did the original pickup sound?I know I am shooting in the dark but I am totally stumped!
Before you buy a Les Paul try EMGs. |
#14 (permalink) |
I had a hum and signal cutting out issue with a pickup ground lead being nearly shorted near the switch lug. It was baffling, but I just grabbed the wire with both thumbs/index fingers and manipulated it at different points until I found the short.
Hi Scott. Thanks for illuminating. Not to be argumentative, but it's actually possible that ungrounded shielding in the pickup cavity can cause noise -- especially with a stacked type design. From my experience and research, I don't think there is any real value in shielding the pickup cavities, while twisting lead pairs, and shielding the control cavity is beneficial. Aluminum shielding under the pick-guard, bridge plate, and/or pickup, but not wrapped around the pickup can reduce rheostat generated noise.
Does learning to make the best of what you have require learning how it functions? |
#15 (permalink) | |
![]() TDPRI Member
If you don't perceive a tonal penalty, then shielding the entire system has benefits in terms of buzz reduction. Note that typical guitar shielding (copper, aluminum) does virtually nothing for magnetic interference at 50/60 Hz. So for a truly quiet system you need hum cancelling + shielding + special attention to grounding and wiring techniques. In most cases I think the hum cancelling itself is good enough, but the Tele bridge in particular is where they can all come in to play. For general info, this link has a really good treatment of shielding and grounding: http://dsp-book.narod.ru/MISH/CH89.PDF Note that they recommend a single point ground at audio frequencies.
#16 (permalink) | |
#17 (permalink) | |
#18 (permalink) | |
![]() TDPRI Member
So...get this.
My pickup has a nickel plated steel baseplate, and has significantly less buzz with a steel bridge plate. I also have very little buzz with pickups having no baseplate. I think the buzz may be related to the material differences between the respective plates. Possibly an impedance difference in the ground paths through the differing materials creating a ground potential difference, or coupling between the plates, or maybe a combination of both. The ferrous plate will definitely inductively couple to the pickup, so the microphonics are likely a function only of the bridge plate material. Quote:
