Old August 3rd, 2012, 01:28 PM   #1 (permalink)
Noiseless for tele???
Hi, i would like to change my tele pickups because the noise is killing my ears. I want a warm, open, lush and sweet sound, and that can take distortion pretty well. I mostly play jazz, fusion, rock, blues, ska and some latin. i never play country what do you recommend?
mandujo is offline   Reply With Quote
Old August 3rd, 2012, 04:03 PM   #2 (permalink)
OG_Stike's Avatar
If you have the $ - I would go with Kinman Broadcasters. If you want to hear what they sound like check out
http://stike.bandcamp.com
All instrumental, all Tele.
OG_Stike is offline   Reply With Quote
Old August 3rd, 2012, 04:08 PM   #3 (permalink)
Stratburst's Avatar
The Kinmans are the current gold standard in noiseless pickups. I have a set of Woodstocks in my Strat and that's part of the reason why it's my #1. Gorgeous tones.
They're worth every penny but bring a lot of pennies.
Originally Posted by Jakedog View Post
Part of your stage presence is your look. If somebody who doesn't know you, can't walk in the door of the bar while you're on break and know at a glance that you're in the band, you are poorly dressed.
Stratburst is offline   Reply With Quote
Old August 3rd, 2012, 06:55 PM   #4 (permalink)
Rob DiStefano's Avatar
bill lawrence l200 set for vintage and an l290 bridge/l280 neck for modern. lots less dollar$ than kinman, and they do have The Tone.
fretted instrument tech ~ custom partscasters
Cavalier Single Coil Pickups
Molon Labe - come and get them!
Old August 3rd, 2012, 07:25 PM   #5 (permalink)
+1 on Rob's recommendation. The L298's are more sweet and fat from what glean.
ZexCoil has some very happening offerings for not too much more $. Definitely worth a try.
Does learning to make the best of what you have require learning how it functions?
Narcoleptigon is offline   Reply With Quote
Old August 3rd, 2012, 08:35 PM   #6 (permalink)
Tele-phone man's Avatar
+1 on the Bill Lawrence pickups. I use the L280TN/L280TL (not officially available, but still available. The L200TL is probably just as nice). Best value noiseless pickups available. Others are different, none are better.
Tele-phone man is offline   Reply With Quote
Old August 4th, 2012, 01:36 AM   #7 (permalink)
I haven't tried the Lawrence pickups. I've used the Kinman Broadcaster set which sounds like a great alnico singlecoil 50s style tele pickup set. I've used Joe Barden pickups which are more hi-fi than stock singlecoils, and which will make a wider range of sounds than regular singlecoils or the Kinmans at various settings on the volume and tone controls on the guitar. I like the Kinmans and the Bardens equally. My only note about the Bardens is that I'd say they sound best through a juicy sounding amp (such as a Vox or Matchless or 65Amps or a JTM45 or a tweed or brown era Fender circuit), they don't sound as good to me through a flat/plain sounding amp.
Old August 4th, 2012, 01:46 AM   #8 (permalink)
I'm a fan of the EMG T set myself. Quite possibly the best sounding tele neck p/u. I have an SPC onboard as well - it's a mid boost that pushes the sound into humbucker territory.
bigbandtele is offline   Reply With Quote
