Old July 29th, 2012, 06:05 PM   #1 (permalink)
HHS tele - 5 position blade options for 2 coil splits and N/B combo
I'm about to install two push-pulls and a toggle on an HHS PU set-up, one switch each to split neck and middle coils and to combine the tele bridge and the neck miini hum (which also gives option of all 3 PUs together) -- but is there a cooler/practical way to do it with a Fender superswitch and a single push-pull switch -- an S1 or some other?
It seems like most who use the 4-pole S1 do the same things you can do with a conventional push pull, and all I seem to see for the superswitch are variations on the Jerry Donahue wiring. Not interested in series combinatinos or OOP for this puppy -- only what I said -- but I don't think I am good at figuring out multi-pole wiring.
Should I just do it the way I know, or does someone have another idea?
52blue is offline   Reply With Quote
