Old July 15th, 2012, 01:09 PM   #1 (permalink)
jmiles's Avatar
4-way switch with P-90s
I have a friend who has a Tele with two P-90s, standard Tele 3-way switch. Can he install the 4-way switch with P-90 pups, for the series/parallel option?
jmiles is offline   Reply With Quote
Old July 16th, 2012, 12:17 PM   #2 (permalink)
metalicaster's Avatar
Yes, you can wire any two pickups in series if you have at least two wires coming out of each.
Keep in mind there may be phase difference issues - swap the wires round till it's loudest.
I would question whether it is necessary with p90s, they are pretty fat sounding already... unless this is rip your head off monster tone he's going for
"Light beer is for people who like having a hangover without having the fun first."
metalicaster is offline   Reply With Quote
Old July 16th, 2012, 12:36 PM   #3 (permalink)
sjtalon's Avatar
May need three, if they have a cover (shield), which would be connected to the neutral coil lead to share the path to ground.
Old July 16th, 2012, 02:07 PM   #4 (permalink)
jmiles's Avatar
He winds his own pups, and is very good at it. I just thought the idea of using a 4-way might not have occurred to him. So,,, if he winds one "North", and the other "South," does he get a monster humbucker in the 4th position?
Old July 16th, 2012, 02:17 PM   #5 (permalink)
waparker4's Avatar
I believe so, but part of the sound of a humbucker comes from the coils being so close together... which doesn't happen in this case
waparker4 is online now   Reply With Quote
Old July 16th, 2012, 03:10 PM   #6 (permalink)
sjtalon's Avatar
Well not monster, but a fatter and more powerful (slightly higher output) sound. Very similar to a humbucker.
You need to have reverse polarity as well, or they will be out of phase actually. But that can be cured with how they are connected.
Same-same pickups can benefit from series though too. In other words one doesn't have to be RW/RP.
Old July 16th, 2012, 04:36 PM   #7 (permalink)
jmiles's Avatar
"Same-same pickups can benefit from series though too. In other words one doesn't have to be RW/RP."
Oh! I know! I have a 4-way in my main Tele, and have put in a few for friends. Just wasn't sure it could be done with P-90s. You have to ground the pup cover separately on a Tele, and I wasn't sure if there'd be some sort of issue with a P-90.
Thanks guys!
Old July 16th, 2012, 04:53 PM   #8 (permalink)
sjtalon's Avatar
I put a mini toggle in my Jazzmaster to get the pups in series and it sounds seller..........but they have plastic covers so it was a breeze
Happy pickin'
Old July 21st, 2012, 04:41 PM   #9 (permalink)
RomanS's Avatar
I've got a Thinline Tele with a HB-sized P90 in the bridge position, and a VVG HCC (a HB-sized cross between a P90 and a Chalrie Christian pickup) in the neck spot - and while I really love the 4th position on all my Teles with "regular" (= lower output Tele or Strat) single coils, I don't find it useful at all with those P90ish pickups - it just sounds muddy and indistinct...
Old July 21st, 2012, 11:45 PM   #10 (permalink)
Mreilander's Avatar
If he's using shielded 2 conductor for the lead wire, he will have no problem connecting them to a 4way. If he's using vintage steel braided wire, it might pose a problem... if the braid touches the wrong component, it will short out with no output.
The baseplates for the P90's should be connected to the shield (bare wire) of the shielded 2 conductor.
Like Us on Facebook!
Mreilander is offline   Reply With Quote
Old July 21st, 2012, 11:48 PM   #11 (permalink)
donh's Avatar
P90s have a back plate which must be separated from signal minus ("three-wire") if you are planning on placing them in a series circuit or doing the safety-circuit mod.
"Everything is a tone control"
-donh-
donh is offline   Reply With Quote
