Old July 14th, 2012, 07:49 PM   #1 (permalink)
How do you visually tell the difference B/W Seymour Duncan and Duncan Designed pups
I have seen pickups that say "Seymour Duncan" on the top and some that say "Duncan Designed".
1. How can one visually identify whether pick ups are "Seymour Duncan" or "Duncan Designed"?
2. If the pickups say "Seymour Duncan" on the top does that definitely mean that they are Seymour Duncan and not Duncan Designed pickups?
3. Or can pickups that say "Seymour Duncan" on the top still be Duncan Designed pickups?
Thanks for any help with this issue.
Navigator is offline   Reply With Quote
Old July 14th, 2012, 08:12 PM   #2 (permalink)
I would say that if they say the name they are definitely Duncans. But maybe put this up at the Seymour Duncan pickup forum or ask someone at the company, since they should know all the details. Too many players without a program in this fast moving world.
George
YoGeorge is offline   Reply With Quote
Old July 14th, 2012, 08:20 PM   #3 (permalink)
oramac7891's Avatar
Number 2 is correct
oramac7891 is online now   Reply With Quote
Old July 14th, 2012, 09:15 PM   #4 (permalink)
Chrismo's Avatar
If it says Seymour Duncan, it's a Seymour Duncan. If it says Duncan Designed, it's a Duncan Designed.
Chrismo is offline   Reply With Quote
Old July 15th, 2012, 06:47 AM   #5 (permalink)
Rob DiStefano's Avatar
that's about it.
fretted instrument tech ~ custom partscasters
Cavalier Single Coil Pickups
Molon Labe - come and get them!
Old July 15th, 2012, 10:12 PM   #6 (permalink)
Plastic covers.....
Do you ever take off the plastic on the Seymour Duncan's or just leave it on?
Landking is offline   Reply With Quote
Old July 16th, 2012, 10:00 AM   #7 (permalink)
benderb9's Avatar
Pickups marked as Duncan Designed are made off-shore for import model guitars from various manufacturers, like my Squire Tele with the two Duncan Designed P90's in it, all Indonesian all the time and always way good. Pickups marked as Seymour Duncan are all Made in the U.S. of A. and will generally have a stamping on the bottom side of SD. All Seymour Duncan pups are Duncan Designed unless one of the other tonemeister's did the design work, but if it was designed on Seymour's dime it then becomes his design.
benderb9 is offline   Reply With Quote
Old July 16th, 2012, 10:29 AM   #8 (permalink)
They're simply marked different. They give it to you straight. Seymour Duncan is the real deal, Duncan Designed is the offshore Duncans.
I have the DD pickups in my Squier VM Jaguar bass. They are are marked Duncan Designed.
Lead Through Light
DucPerLucem is offline   Reply With Quote
Old July 16th, 2012, 10:51 AM   #9 (permalink)
clayfeat's Avatar
I heard that the Duncan Designed pickups were designed by stage and screen star Sandy Duncan. Is that incorrect?
clayfeat is offline   Reply With Quote
Old July 16th, 2012, 11:02 AM   #10 (permalink)
63dot's Avatar
Some of the antiquity Duncans, a few Duncan reissues, and some pickup models of early PAF and Fender models, like the full sized '59, do not have any writing on top. The ones with the logo on them are usually the hotter Seymour Duncan pickups like the Scremin' Demons, Gus Gs, Hot Rails, Cool Rails, single coil space 'lil '59, or active pickups.
http://www.musiciansfriend.com/acces...FSUbQgodIzEvdA
http://www.musiciansfriend.com/acces...-guitar-pickup
http://www.musiciansfriend.com/acces...ecaster-pickup
http://www.musiciansfriend.com/acces...invader-pickup
http://www.musiciansfriend.com/acces...ker-pickup-set
http://www.musiciansfriend.com/acces...-humbucker-set
63dot is offline   Reply With Quote
