Old June 26th, 2012, 12:58 AM   #1 (permalink)
whats the best Tele jazz neck PickUp?
I was wondering what's the best nonrouted (or slight routing) neck stacked humbucker pickup for play jazz. Any thoughts? Thanks, Paul
PS Check out the Catalincaster
http://www.pontrello.com/catalincaster.html
catalincaster is offline   Reply With Quote
Old June 26th, 2012, 07:35 AM   #2 (permalink)
I'd check out the DiMarzio Area T. But really, you can play jazz with any Tele neck pickup.
No trees were killed in the posting of this message, but a large number of electrons were terribly inconvenienced.
tpaul is offline   Reply With Quote
Old June 26th, 2012, 07:59 AM   #3 (permalink)
elelpe's Avatar
Check out Wilde Bill's NF: L200TN/L202TN and L280TN. The Catalincaster is purdy!
elelpe is online now   Reply With Quote
Old June 26th, 2012, 08:18 AM   #4 (permalink)
Le Jab's Avatar
I reckon the Lollar Charlie Christian. Tim Lerch does a Youtube demo worth watching......
http://www.youtube.com/watch?v=JgYsugjmITc
ETA the Lollar CC is single coil.
Le Jab is offline   Reply With Quote
Old June 26th, 2012, 09:16 AM   #5 (permalink)
EMG t-set with an SPC tone control.
bigbandtele is offline   Reply With Quote
Old June 26th, 2012, 09:44 AM   #6 (permalink)
blowtorch's Avatar
you may laugh, but the GFS Fatbody tele neck pickup is very very good.
blowtorch is offline   Reply With Quote
Old June 26th, 2012, 09:51 AM   #7 (permalink)
I also think that any "fat" single coil would do the trick. Mine is an Harmonic design p90 and it is perfect for jazz too. A mini humbucker would work very well too, but your tele might need a bigger route.
Alain77 is offline   Reply With Quote
Old June 26th, 2012, 10:27 AM   #8 (permalink)
Steveareno's Avatar
[QUOTE=Le Jab;4256681]I reckon the Lollar Charlie Christian. Tim Lerch does a Youtube demo worth watching......
Was tempted by the Lollar CC (they sound and look great), but got paranoid about noise and went with Bill Lawrence/Wilde twin blades: L-45S in the neck. Nice balanced tone and super quiet (can't stand buzzing, or hum). I reckon twin blades have a little bit of the CC sound in a smaller, modern unit. Sounds warm, jazzy and smooth thru my little Polytone.
Swang on,
Steveareno is offline   Reply With Quote
Old June 27th, 2012, 11:04 PM   #9 (permalink)
I think stock vintage-type Tele neck pickups have a great jazz sound.
davidge1 is offline   Reply With Quote
Old June 28th, 2012, 09:10 AM   #10 (permalink)
Rob DiStefano's Avatar
the BEST pickup for ANYTHING is the one that sounds "best" to .... you.
does that sound right? or am i stupidly incorrect? gee whiz ......
fretted instrument tech ~ custom partscasters
Cavalier Single Coil Pickups
Molon Labe - come and get them!
Old June 28th, 2012, 07:50 PM   #11 (permalink)
I like this answer more all the time; esp variations of it for all the "what is the best" questions out there.
Having said that . . . if you need a "typey" sound, mini-humbuckers are avilable, too. I think low-output pickups, too, maybe even AlNiCo II magnets, help retain the wood and string sound. Oh, yeah put a heavier string on.
The "jazz" tone everybody chases is an outcome of the state of the art in guitar/pickup/string/amp that was available a long time ago. So kind of sad unless you happen to love it!
Greg
Greg.Coal is offline   Reply With Quote
Old June 28th, 2012, 08:08 PM   #12 (permalink)
I like my SD vintage stack neck pup for jazz and blues. For me, it's more about the amp. A lot of neck pickups sound good thru a Roland JC or a Mesa Subway Blues.
tele_bob is offline   Reply With Quote
Old June 28th, 2012, 10:33 PM   #13 (permalink)
daveaskren's Avatar
Sorry, but I have a thinline squire tele w humbuckers so I dropped a Duncan '59er in the the neck....! Fat!
daveaskren is offline   Reply With Quote
Old June 28th, 2012, 10:45 PM   #14 (permalink)
Simple,.......... Ron Kirn, neck pickup. Roll off a bit of the tone a bit. Perrrrrrrrrrrfect! Warm, Woody, clean, harmonic chime, Oh yeah, and a Barnbuster. Century old wood. I don't use my f hole guitar anymore. Then sometimes to freak my jazz brothers out I use the bridge pickup to shake things up a bit....come on.....it's jazz!!!!
guitarbiker is offline   Reply With Quote
Old June 28th, 2012, 10:55 PM   #15 (permalink)
+1 on either of those. The L280TN is a little higher output and "wider" and more even sounding. The others are 50's style. Use a low capacitance cable, 250k pots, and put your tone at ~5 for a good jazz tone.
Does learning to make the best of what you have require learning how it functions?
Narcoleptigon is offline   Reply With Quote
Old July 3rd, 2012, 12:02 AM   #16 (permalink)
Good question.
I am a Jazz player with a number of old Gibson archtops, a couple of Gretschs, a Les Paul, a Strat, and four vintage Telecaster. I really, really dig Telecasters. The blend of Jazz and piercing twang performances out of Telecasters has been a quest of mine for some years now. Having played lots 30s and 40s Swing and plenty of Bebop, I know what a good Jazz guitar should like.
All of my Telecasters have Bardens in the bridge position and variations of humbuckers in the neck position. The 60 has a Barden, the 61 Esquire has a Seymour Duncan "Vintage Stack", the 66 has a Gibson 490R, and my 73 Custom I rebuilt the original Wide Range Humbucker. All the pickups in these guitars have individual series/parallel switching.
So here is my recommendation: The best sounding pickup of this bunch for the application of Jazz is the Duncan Vintage Stack in the Parallel mode. I also have it wired to a secondary option on a 4-Way pickup selector switch that runs said stack pickup through a large value cap. It sounds really good. Another advantage to this pickup, along with no routing of the body cavity required, is the price, at about $78 bucks.
Name:	Trace Telecardos Plus One 1.jpg
ID:	133174   Click image for larger version
Name:	Fender Esquire (1961) 7.jpg
ID:	133175   Click image for larger version
Name:	Fender Esquire (1961) 23.jpg
Name:	Fender Telecaster (1960) 39.jpg
May the "Twang" be with you!
Twinkie is online now   Reply With Quote
Old July 3rd, 2012, 01:47 AM   #17 (permalink)
Ian
Ian's Avatar
Joe Barden
"Practice , practice EAT PRACTICE!!!" Tommy Tedesco
Ian is offline   Reply With Quote
