Old June 23rd, 2012, 05:50 PM   #1 (permalink)
Pickup Polarity Question
I built a parts caster and wanted to use some pickups I have laying around. I have a Keystone bridge and a Fender 62' neck. I wired it up, and they are out of phase with each other. The middle position is less than 1/2 the volume of either pickup individually. Is it simply a matter of reversing the wires of one of the pickups wired to the pots, or are the 2 not compatible?
jklotz is offline   Reply With Quote
Old June 23rd, 2012, 07:21 PM   #2 (permalink)
jefrs's Avatar
Yes.
The neck pickup usually has one wire connected to its case, that is cold/ground. Test ground continuity with meter. Some neck pickups are 3-wire and can be easily reversed.
The bridge pickup is usually grounded via a separate wire to the mount. It grounds the pickup base and bridge plate. So it should be easiest to reverse the bridge pickup.
Old June 23rd, 2012, 11:03 PM   #3 (permalink)
sjtalon's Avatar
Usually the Keystones have a dedicated bridge plate ground. You have 3 bridge pup wires right ??
Switch the black and white (coil wires), the blue is the base plate ground and remains on the back of a pot.
