Old June 18th, 2012, 12:33 PM   #1 (permalink)
sketchanderase's Avatar
Wiring preamp question
So, I'm working on a traveler guitar concept, and what I want to do is have an onboard preamp so that I can plug into headphones or have a small speaker to plug into. I have found http://www.guitarfetish.com/Onboard-...nes_p_567.html this which looks good to me, the question is how to wire it.
My thought was to have a master volume and tone with the guitar (which has 2 humbuckers already). My question was, does this go in as the master volume? or as a seperate pot. The other thing mentioned in the description of the product is using a switch to turn the amp on or off, would this be needed or recommended? To install a push pull switch would that then be the master volume with the preamp pot being the preamp volume and would it be needed to function? Instead could I have a simple switch to turn the preamp on or off, and would it function properly through a standard amp then too? or is it worth to shell out the only $9 more for the push pull? I'm only really asking because I am low on space to keep the size down in this guitar.
Could anyone make a simple diagram of how this would layout for me? I'm not much used to electronics yet.
Any help is greatly appreciated, thank you very much.
sketchanderase is offline   Reply With Quote
Old June 18th, 2012, 01:07 PM   #2 (permalink)
For on/off a stereo jack is usually used w the second contact used to ground the battery negative like an EMG set up. Pluging in turns it on. Usually I don't try to disuade/redirect the idea in the post...but a headphone amp is tiny and will have effects. For that matter my Zoom box that does everything but walk the dog has a headphone out and it is no hassle to travel with its 10x5x2 inches and less than a lb. in weight. Unless you want to have a low Z out in general, an on board pre/headphones is unnecesssary.
Teleterr is offline   Reply With Quote
Old June 18th, 2012, 05:28 PM   #3 (permalink)
Well, I was considering putting in a speaker as well, but I was assessing my options before going through with it. The other thing I was thinking was building a Noisy Cricket amp http://www.beavisaudio.com/projects/NoisyCricket/ but I wanted to know my options and like the idea of plug and play better than having to deal with a separate box to carry around with it. This is a dedicated travel guitar, so I'd like to keep it simple but self contained.
