good single coil bridge PU for a Paulowinia body Tele?
Hi guys,
I have a parts Telecaster with a Paulowinia body from GFS and GFS pickups in it. The body is very resonant and is pretty loud acoustically, and seems to have a very naturally bright and chimey sound, even with 11's as the string gauge. I have a mini HB in the neck that sounds beautiful. Has the right combination of warmth and sparkliness for a very nice full sound. There's a GFS Fatbody pickup in the bridge. It's full of high end, but is a bit too bright to be used on its own, even with the tone rolled off. It just sounds way too thin in comparison to the neck pickup. Maybe it's because the body doesn't have a ton of natural low end, but I'm not sure. Does anybody have any recommendations for a good bridge PU? I was thinking one of the Seymour Duncan Alnico II pickups might tame the guitar a little bit, such as the Alnico 2 Pro or the Jerry Donahue pickup, as they have a little more warmth and less treble than most single coils. |
Dimarzio twang king!
MIM FSR BSB tele with reversed control plate with forrest lee jr. b bender>boss-tu-2>wampler paisley drive>modded ts-9>rockett animal>ego compressor>boss super chorus>pepperoni phaser>tuna melt tremolo>Wampler Analog Echo>Boss DD-6>Dr.Z Maz 38sr 212. |
![]() Poster Extraordinaire
any quality pickup will be great….
Ron Kirn
“Silence in the face of evil is itself evil: God will not hold us innocent. Not to speak is to speak. Not to act is to act.” — Bonhoeffer www.ronkirn.com |
#6 (permalink) | |
Interesting...Rob has built several P-wood Tele's. I wonder if he's ever had one sound really bright? I don't know of any body wood in that thickness that would have a low bass resonance. I think the dimensions limit the resonance to upper bass at the lowest, even with P-wood. I could be way off on that. It could be that the neck/body combo puts the guitar's resonant frequency below the range of the instrument, so it's missing that boost in the bass region? I think my Parker has a bass resonance at ~120Hz. You may be unlucky in that something in the makeup of the guitar creates a bright resonance that offsets the balance of the instrument. It's really impossible to predict these things. What kind of bridge/saddles do you have? Do you have 250k pots?
Is the neck joint really tight? Is there possibly some loose cracked finish in it, or is it shimmed? Some people think direct wood to wood contact in the neck is the best solution, but I wouldn't sand it out. It's too easy to ruin the coupling, and the angle. If your interested, I have an interesting and easy to implement neck joint idea based on the Taylor neck joint.
Does learning to make the best of what you have require learning how it functions? |
#8 (permalink) | |
#10 (permalink) | |
![]() fretted instrument tech ~ custom partscasters Cavalier Single Coil Pickups Molon Labe - come and get them! |
