Make the D pole higher and the G pole lower
Seems like the plain G is considered too loud relative to the other strings.
So do pickup makers address this by making the D pole higher and the G pole lower? Which pickups are these? |
This has been an irk with me forever.
Fralin has one ready-available. However, Neil Young's tech, Larry Cragg, has had Fralin make small runs in excatly what you are wanting- the D pole taller then Fralins already-available flat G/ raised D model. I guess it would be a custom pup. Mention the Larry Cragg mod. I use the G&L ASAT Classic pups with adjustable poles in my cheapie. They sound very good to me. No need to go the wound G route: your bending intervals will suffer from that alot.
. KENNY POWERS for Precedent !! Last edited by Doug 54; May 31st, 2012 at 09:22 PM. |
The Fender 62RI pickups have staggered poles with the D the highest but the G is still higher than the E and B. That isn't a problem for me as I use a wound 3rd string.
"Life is mostly Froth and Bubble" Adam Lindsay Gordon |
Kinman's have an improved, well balanced stagger.
on most standard single coils you can just push the G pole down, or tap it down if it's too tight to push. just don't push too far.... It's pretty silly that everyone wants their guitars and pickups to follow vintage specs, but they don't want to use the heavy strings with wound G that these things were designed for. |
This guy does not have a website. His email is tilsonpickups@gmail.com. He has built me several pickups to my specs. All have been awesome. His prices are quite reasonable as well. I am sure he could build you whatever you were looking for.
It /is/ possible to push an alnico pole magnet in or out of the coil to adjust height.
Do not strike them as brittle and may shatter, push. Ball-bearing as pusher, small nut as catching cup, vise. Once shifting they can be pushed with thumb even partly on the guitar for final adjust. Quite easy on a strat pickup as without a base plate or cover.
#12 (permalink) | |
Can't take Viagra anymore. It makes me stiff all over. |
This has been a bugaboo for me the past 30 years, and all that time my solution on Teles and Strats is to lighten the G string by a notch or two. When using 10s I drop the G from .017 to .016 or .015. Sounds better and more balanced to me all the way around.
I would like a raised D all by its lonesome.
---------- Tech Geek and Sensitive Artiste String bender ordinare! |
#14 (permalink) | |
And go to a bigger D.
Used to be a Gibson-holic, but recovering nicely with Teles. |
