Old May 15th, 2012, 02:03 PM   #1 (permalink)
Wilde Question follow up
Okay, the Armadillo Guitar bridge *IS*
non-magnetic, per the folks at
AG.
I have one on the way. I hope it solves
the problems I've been having. I can live
with hypersensitivity to knocks, bumps, strap
lock moving in its socket, etc.
What I CAN'T deal with is the feedback from
even the most moderate gain. At stage volume,
even a slightly distorted sound elicits squeals from my amp behind me.
I suppose I'll find out. I order the "L" model designed for the saddles.
I'm keeping the Stew-Mac compensated saddles that are on the guitar\
bridge currently.
If anyone has ever made this change using a Wilde 290TL, I'd love to hear from you regarding how it changed the sound of the instrument for you.
Dr. Pants is offline   Reply With Quote
Old May 15th, 2012, 02:36 PM   #2 (permalink)
Are you sure its not a microphonic tube? And will it take over the living room like the Australian vibrating clocks?
Teleterr is offline   Reply With Quote
Old May 15th, 2012, 09:50 PM   #3 (permalink)
Yes, I'm sure. Absolutely, positively beyond all
doubt and question.
for more info see the thread titled "that Wilde question"
Old May 15th, 2012, 10:36 PM   #4 (permalink)
Tele-phone man's Avatar
I had exactly the same problem with my L290TL in a stamped steel bridge. I went back to my Gotoh brass bridge, and ALL squeal went away. It was amazing.
As an experiment, I had the guitar plugged into an amp as I removed the pickup from the bridge. I pulled the plate with the pickup attached, then removed the pickup mounting screws. I could tap on the pickup while it was still within the plate and hear all of that knock and noise. I just pulled the pickup away from the plate, and ALL of the sensitivity to knock disappeared. I could go back and forth and make the microphonics appear and disappear at will. It was dramatic.
As an extra added bonus, the pickup just sounded better in the brass bridge. It was less harsh, not quite so edgy. Also, the noise cancelling ability was much better in the brass bridge (perfect, in fact; absolutely silent), but in the steel bridge I still had some hum due to its distortion of the magnetic field. You really are doing yourself a favor getting the new bridge for this particular pickup.
Since then, I've sold my L290TL and replaced it with the L280TL I originally had. I preferred the more traditional, less midrangy sound of the L280TL. Maximum twang.
Tele-phone man is offline   Reply With Quote
Old May 16th, 2012, 12:00 AM   #5 (permalink)
I know. You sold it to me!
This is your pickup we're
talking about JVB.
I'm curious to see what I'll
wind up with once the Armadillo Guitar
bridge is installed with the pickup.
Old May 16th, 2012, 01:10 AM   #6 (permalink)
There you go. I knew Gotoh made a brass plate. Not anymore, I guess?
Does learning to make the best of what you have require learning how it functions?
Narcoleptigon is offline   Reply With Quote
Old May 16th, 2012, 01:18 AM   #7 (permalink)
I don't know, I never checked the Gotoh.
I have one already, and using a pickup, I tested
it and found it to be magnetic.
Whereas the good folks at Armadillo Guitar
confirmed their "L" model to be non-magnetic brass.
Apparently not all brass is created equal.
Either way I have an Armadillo Guitar bridge coming this week.
I really hope it works, as I really dig the 290TL in the guitar I
have it in.
