Old February 13th, 2012, 03:06 PM   #1 (permalink)
CV50 Pickup Upgrade to mini-bucker
Hi Guys,
I am looking at putting an antiquity 2 bucker in the neck and an antiquity 2 in the bridge - would these two work well together? and would i need to change anything else? (apart from the pickguard) or would you recommend something else? i am looking for a vintage tele sound with that bit extra from the neck bucker. the gibson mini-bucker looks good to me also - but would that work with the SD bridge pup?
Many thanks
mr.boosh is offline   Reply With Quote
Old February 13th, 2012, 03:15 PM   #2 (permalink)
also what are the wilkinson pups like? they look pretty good at a great price
Old February 13th, 2012, 03:30 PM   #3 (permalink)
I just finished one with GFS single coil in the bridge position and mini-hum in the neck spot. A wonderful sound emerges with the switch in the mid position - I think because the bridge pup is out of phase with one humbucker coil and in phase with the other.
Balancing output may be tricky; the neck pup is intrinsically louder. I have the bridge up near the strings, the mini-hum adjusted downwards. Or you could go with a hotter wind on the bridge pup. Definitely a combo with possibilities.
"Let's take everything we think we know about solid body electrifying guitars and throw it out the window. Let's start over." ---Leo Fender
PumpJockey is offline   Reply With Quote
