Pickup winders, why hasn't this been done yet? (Widerange humbucker based)
So I started thinking the other night. Why can't a humbucker be designed with a coil split and a coil tap? So here's my thought.
Design it like a Wide Range Humbucker with magnetic pole pieces, but all on one side instead of split between both bobbins. Wind it like a normal Wide Range or however you like, but have the screw coil coil-tapped so that when you split the pickup into single coil mode, it activates the coil-tap so that the single coil is equal in output to humbucker mode or whatever output you want the single coil to be. Can this be done? It's not like it was a tough concept to think up which leads me to believe that it's either difficult to execute or just not possible. |
#4 (permalink) | |
If you put all the magnetic pole pieces into one coil, the other coil (screw coil) would still need some form of magnetization - ie. it would need a bar magnet. Otherwise it would never be a humbucker, it would be a single coil pickup with a dummy coil in series.
A humbucker is two coils electrically and magnetically out of phase, so that external noise is cancelled while the two 'half' string movement induced signals sum. Remove one of those magnets and you lose half of the string induced signal. |
When you say humbucker output matching the split single coil output, do you mean that the humbucker runs on two tapped coils?
So the humbucker would be two tapped single coils, and when split, you use an untapped single coil? Could be interesting! |
It doesn't work that way. First, a WRHB has 12 magnetic poles. Only half are exposed/adjustable. If there are no magnets for the second coil, you're basically making a single coil with a dummy coil for noise cancellation. Second, tapping or splitting a pickup reduces inductance and resistance. This will always result in a weaker, brighter tone.
--Garrett-- |
