Old August 13th, 2011, 04:42 PM   #1 (permalink)
tattoedsailor's Avatar
Neck Pup real muddy
Just like title says.. I got a set of Seymour duncan Antiquity II in my Tele. Love the bridge, but the neck is real bass heavy a little muddy sounding. I've read that depending on how guitar is wired makes difference in how neck pup sounds. I think its wired to 50's vintage which might explain why its so muddy.. Any suggestions would be great. It might just be the pickup.. If so I might start looking for something that's a little brighter sounding. Recommendations?
tattoedsailor is offline   Reply With Quote
Old August 13th, 2011, 04:48 PM   #2 (permalink)
musicmatty's Avatar
Check out Ebay for a CS Texas Special neck pickup or and American Standard neck pup..there both AlNiCo 5 pups..The 5s have that nice Glassy sound. Mixing and matching pups is a good thing in my opinion. Good luck
Heres my neck position @ 1:50 into the video..this is the CS Texas Special pups.
musicmatty is offline   Reply With Quote
Old August 13th, 2011, 05:06 PM   #3 (permalink)
I have some Velvet Hammers that are AlNiCo 2 and it is sort of muddy in the neck.With only 4.9 DC resistance.Good output tho.
Teleterr is offline   Reply With Quote
Old August 13th, 2011, 05:08 PM   #4 (permalink)
Or doesn't the 2 refer to the magnets?
Old August 13th, 2011, 05:12 PM   #5 (permalink)
rangercaster's Avatar
that would explain a muddy sound ... how does it sound in the middle position ??? have it modified to the modern wiring config before you spend your money on pickups !!!
"Unum saltum et siffletum et unum bumbulum"
Old August 13th, 2011, 05:28 PM   #6 (permalink)
What changed in the wiring ? Never mind I was thinking I was in the Strat Forum
Old August 13th, 2011, 05:36 PM   #7 (permalink)
Exactly, 50's wiring leaves the neck pup muted. You need to wire it to modern, or 60's, specs, then the tone control will work with both pickups.
gkoelling
'56Teleman is offline   Reply With Quote
Old August 13th, 2011, 07:52 PM   #8 (permalink)
All right looks like its 60's specs.. Looks like theres a treble bleed also.
Old August 14th, 2011, 06:47 AM   #9 (permalink)
Axis29's Avatar
Try lowering the pickup?
John F.
TDPRI # 1764
Please check out the Fredericksburg Blues Society
or, if you're really bored, A year in Guitar
Axis29 is offline   Reply With Quote
Old August 14th, 2011, 10:15 PM   #10 (permalink)
I may just get a Dimarzion Twang King for the neck... I just put a set in a buddy's guitar. Love that neck pickup. Is their any special wiring instructions that I should know about when mixing Dimarzio & Seymour Duncan? I'm going keep the SD bridge.
Old August 14th, 2011, 10:21 PM   #11 (permalink)
kp8
kp8's Avatar
Take the cover off.
Old August 15th, 2011, 10:32 AM   #12 (permalink)
rokdog49's Avatar
You'll probably like the Twang King. I have a "Rumplestiltskin" Blues Special (no cover) in the neck of my other Tele and it is brighter and has more oomph! It's my fave' between the two. Had the stock Mexican pups in both b4 and they came out immediately.
rokdog49 is offline   Reply With Quote
Old August 15th, 2011, 11:09 AM   #13 (permalink)
^^ I all ready heard the pup. I installed them in friends guitar. My chin about hit floor when I heard the Twang king neck.. I just picked one up for $45 @ local store.
Old August 15th, 2011, 12:41 PM   #14 (permalink)
Not sure about Duncan and DImarz, but, Fender/Duncan do not play well.
Have to reverse wires.
A person who won't read has no advantage over one who can't read.....
Mark Twain
uriah1 is offline   Reply With Quote
Old August 15th, 2011, 01:07 PM   #15 (permalink)
Before changing PUP's, reduce the C (Capacitance) -load on the PUP via a lower C cable. I find ~200pf to work well with most PUP's. Your amp may have C on the input. Check the schematics. That C should be factored into the total C-load. Seriously, C-load makes a notable difference. It's no different than a tone knob.
Does learning to make the best of what you have require learning how it functions?
Narcoleptigon is offline   Reply With Quote
Old August 15th, 2011, 01:26 PM   #16 (permalink)
Hoopermazing's Avatar
Installing a GFS Fatbody pickup and doing this to the pickup cover significantly livened up my neck pickup situation. The stock pickup was muddy even for jazz, IMO.
* The image is of boneyguy's guitar... which is where I got the idea.
Hoopermazing is offline   Reply With Quote
Old August 15th, 2011, 02:34 PM   #17 (permalink)
One thing I did with my stock mim alnico v I believe was to just take that cover off. Scrape all that wax out. Had it uncovered for a while liked it, very very bright. I just put the cover back on. Sounds great actually. Taking all that wax out really cleared it up.
Roku is offline   Reply With Quote
