Problem with Hamer Artist Seth Lover Pickup's
I picked up a used guitar. Hamer Artist and I've owned one before. I noticed the Neck pickup was flipped 180. When I got it home I put new strings on it and flipped it back 180 to where I thought it should be. The pickup's are Seth Lover and they look like they are wired according to the Seymour Duncan web site wiring diagram and correct polarity. In fact the soldier looks to be factory. The pickups sound fine by themselves. However they cancel each other out when I select both pickups and I get a Wah Pedal effect with the tone knob. I have not tried flipping the pickup back around yet, but that's going to be my next step, but I won't have time tonight. The neck pickup measures 7.5 K and the bridge 8.0 K ohms. With both pickups selected I'm reading 3.9 K ohms. Are humbuckers polarity sensitive like this or do I have another problem?
They are absolutely polarity sensitive. You now have them out-of-phase. Instead of flipping the pickup back around, you can reverse the hot and ground leads of one pickup, so long as the shield connection of that pickup has its own conductor to ground.
Rotating the pickup did not put it out of phase and if the pickups have a traditional single lead and shield you cannot swap them.
This guitar was wired with the neck pickup mounted reversed and either magnetically of electrically out of phase, ala Peter Green. To "correct" this, you will need to either flip the magnet on one pickup or modify the wiring at the pickup (unless the pickup has multiple leads, in which case you can re-wire it in the control cavity).
Don |
#4 (permalink) | |
I'll take it apart this weekend to see what I find under the cover. I've never messed with humbuckers but I'm assuming you mean the magnet without the windings. Hopefully it's just re soldiering some wires. Thanks... |
Peter Green was not a soldier but he probably knew how to solder.
I am the center of the universe and so are you.
Before you go too crazy with it, try backing the volume down a hair on ONE of the pups, when you have them both on. This should warm the tone up quite a bit. Some people like the blend of tones that a two-volume/out-of-phase set up can give you - some not so much. It's only gonna be nasty thin with BOTH volumes on "10".
Who was Peter Green? Legendary British blues guy, was the guitarist who took Clapton's place in John Mayall's BluesBreakers (that's him on the second album "A Hard Road"), founding member of Fleetwood Mac (gone before they went all Buckingham/Nicks pop-supergroup). Dropped out of music with severe mental issues, has come back a bit lately. One of his notable accomplishments was that early in his career, he had his guitar tech "deep clean" his Les Paul, and in the process the tech accidental installed one of the humbucker's magnets reversed, putting the pups out of phase (so the story goes...). It became rather a trademark of his, getting some sweet tones like no one else had produced (to that point) out of an LP.
YMMV - I been wrong before... |
#8 (permalink) | |
Thanks! |
#10 (permalink) | |
