Ideas for Nashville Tele S-1 wiring
What are the potentials of a Nashville Tele with the S-1 Switch?
All ideas with schemes are welcome. Thanks |
I did this just as a mental puzzle, but it shows the connections for an S-1. The mid of each of the 4 sets is the common - the outer two the up and down (labeled there as s and p for series and parallel)
Hey
Thanks a bunch. That looks great and has everything I'd like. Ideally, I would like exactly the same S1 UP configuration and this S1 Down configuration: 5: N 4: M+N -S 3: M 2: B+M -S 1: B |
With a single wafer switch, your options are limited. I'll have to think about what is possible.
And I forgot to mention that double wafer switch doesn't fit well inside a tele control cavity. On mine I had to make a custom control plate, as I didn't want to route/chisel the wood. |
#9 (permalink) | |
Try this. There are some long lengths of wires, care should be taken s.t. they don't end up acting as antennas. If you're not used to wiring complex stuff I would suggest taking it to a competent tech.
#11 (permalink) | |
Won't I need to use an extra ground wire for the series neck+bridge? I can do it with the neck or the bridge pickup but prefer the neck. Where should that extra wire go? I think that I can manage this with a proper schematic. I've wired a double fat strat using two push pull pots for phase shifting and coil splitting capability. It took a while but still works! Your understanding of the S1 switch is really ahead of the curb. I think that even fender has underutilized this unique piece of equipment. |
No extra ground required for neck or bridge. With this scheme, the middle pickup's ground wire is switched for the 'series' settings. Typically the middle pickups don't have shield covers, anyway.
#14 (permalink) |
Ah, I meant series neck/mid (if there was neck pickup cover) which I think you understood. Sounds great, I need to order a pickguard from warmoth so it will be a little while but I will let you know how it turns out.
Thanks! |
#15 (permalink) | |
It lacks Middle pickup alone, but has Neck and Bridge in series. Some other ideas : http://www.geocities.jp/dgb_studio/3svari2_e.htm#61 http://www.geocities.jp/dgb_studio/3svari2_e.htm#58 http://www.geocities.jp/dgb_studio/3svari2_e.htm#32 (w/ standard 5-way) http://www.geocities.jp/dgb_studio/3svari2_e.htm#21 |
#16 (permalink) | |
Hi again is it possible with this? http://www.stewmac.com/shop/Electron...h_E-Model.html Has anyone used one of these? Will it really help cut down on noise? Thanks |
#17 (permalink) | |
Noise canceling - with 3 (non-noiseless) single coils, you're going to have to decide what you want well in advance. having the B&N pups wound oppositely to each other with their poles reversed gives you canceling in the middle (B&N, in your 5-way) position. Most Tele sets of B&N are reverse wound - designed for a 2 pup guitar. Then you have to choose which way the mid pup is wound - opposite the b or the n. Opposite to the bridge makes the B&M position noiseless, but not the M&N.... and vice versa. having both the B&N pups wound the same and the M opposite to both gives you noiseless in the B&M and M&N - but not the B&N. it's going to depend on what positions you think you'll be spending the most time and what's available in the pick-ups you like... mostly the latter (unless you have them custom wound). |
