Hot Rodding the Tele!
I've posted a few weeks back about needing something more from my tele (I've recently replaced it at the gigs with a Strat....(gasp!)
I want to Hod Rod it, to match up better with the Les Paul Deluxe (which has Mini-Humbuckers). I still want it to be a Tele, but a fat Tele. I want the output more in that ball park. Any suggestions? I'm open to all possibilities here. Thanks.
Yeah, I'll get around to it. |
Mini HB or P-90 neck and a Broadcaster bridge PUP, maybe a BG1400 bridge PUP.
A Twin always will cut it... but I don't recommend it for everybody. It's like a big dog, you have to take responsibility for it. Not to mention... be prepared to lift it. BTW, how $good$ a guitar is, is no indicator of how badly it can be played! |
Hi,
I do own a 52 Hot Rod Tele for a few days now. And I really LOVE the mini-humbucker in the neck position. I highly recommend it. It doesnīt suck away the treble like normal humbuckers do (but you probably know that, because you own the Les Paul Deluxe). It doesnīt rob the Teleīs identity. Itīs still a Tele, but with a very full and fat tone. Go for it! And combine it with a slightly hotter bridge pickup, so that the volumes of the two PUs may match. But it doesnīt need to be too hot, I guess the Broadcaster PU, as mentioned above, would be a great choice. Daniel |
I'm running a Lollar Special T in the bridge and a mini HB in the neck, couldn't be happier. The Special T is higher output, a little rounder in tone, but still has some twang to it, sounds great with the mini HB (also Lollar)
A Tele is not a Les Paul.
However, if you need a little more output, there are some possibilities. I've used a clean boost in the past. Just make sure you roll off the tone knob...
Squier CV Tele, Squier 51, Winfield Typhoon, Pathfinder 15R, VCXD. |
#6 (permalink) | |
True, When I use the Seymour Duncan PUP Booster with single coils, it does fatten them up, especially with the resonance shift employed. And with the 2 resonance setting I don't even have to come off the tone setting either. Easier to reverse than a pickup swap too. ;)
How about a Duncan Little 59 (or Hotrails or something similar) in the bridge, and using the four conductors for coil-splitting? Anybody try this?
Hey Idaho,
Try a Don Mare Tweed Monster in the bridge and one of his "S" types for sweet strat neck sound in the neck. This is a really nice combo that has nads. Retire that strat and bring back the Tele! Barncaster |
Hi,
I use a Rio Grande Muy Grande bridge pickup in my Tele, and I think it matches up well with my Les Paul Deluxe. I'd suggest visiting Rio Grande pickup website... |
I put Lollars in my '69 Thinline and the tone, when pushed, is decidedly fat & full. I have the (already recommended) Special T in the bridge and a Charlie Christian in the neck. The wiring is non-standard, as I have a four way switch set up thus:
- bridge - bridge & neck in parallel - neck only - bridge & neck in series Finally, I have a push/pull tone pots that engages a .0047 uf cap for the bridge pickup only when pulled. This is the "cocked wah" tone that's usually associated with Esquires. It's very fat on it's own and when you mix it in with the neck pickup in series watch out.
Jemima surrender. That's all ya hafta do. I'll bring over my Fender & I'll play all night fer you. |
#12 (permalink) | |
I was thinking of switching to Lollars but why fix it if it ain't broken, right?
Guitars: 1997 Fender American Telecaster :: Fender '72 Telecaster Custom (reissue) Pedals: Analog Man TR-2 :: Analog Man King of Tone :: MXR Phase 90 (1977) :: Boss FV-500H Volume Pedal :: Boss DD-7 |
