Old April 23rd, 2010, 12:51 PM   #1 (permalink)
chipbutty24's Avatar
How to mount a P90 in a Tele in the neck?
I want to put a P90 in the neck of my MIM tele body. Question is how is it mounted? To pickguard, bottom of route, dogear or soap? Thanks.
chipbutty24 is offline   Reply With Quote
Old April 23rd, 2010, 12:58 PM   #2 (permalink)
jjkrause84's Avatar
Connected to the wood would seem to be the first option
jjkrause84 is offline   Reply With Quote
Old April 23rd, 2010, 02:08 PM   #3 (permalink)
Anyone have a picture of what this looks like. Never used a P-90 before. Did a bunch of searching but came up empty handed. Thanks.
Old April 23rd, 2010, 02:12 PM   #4 (permalink)
BigDaddyLH's Avatar
Well, here's the Fender JA-90:
If you look closely at the pickups, you see the screws between the pole pieces. Those screw the pickup into the wood.
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.” -- Charles Bukowski
BigDaddyLH is online now   Reply With Quote
Old April 23rd, 2010, 03:45 PM   #5 (permalink)
Excellent. Thanks!
Old April 23rd, 2010, 04:04 PM   #6 (permalink)
If you're mounting to the wood, don't forget thet you will need to add springs or foam under the pup to allow for adjustment.
mike shaw is offline   Reply With Quote
Old April 23rd, 2010, 04:07 PM   #7 (permalink)
BigDaddyLH's Avatar
Here's a diagram from Warmoth:
Old April 23rd, 2010, 04:12 PM   #8 (permalink)
mgwhit's Avatar
And I'm pretty sure the MIM Standard neck route won't fit a soapbar style pickup without additional routing. (It will take a humbucker, however).
mgwhit is offline   Reply With Quote
Old April 23rd, 2010, 04:37 PM   #9 (permalink)
Awesome, thanks!
Old April 23rd, 2010, 04:38 PM   #10 (permalink)
I have found a few internet postings on that topic. A few say no but the majority say the route in modern MIMs is as wide as a P90 and as tall as an HB. Saves on tooling. I'm gonna pull the PG off tonite and check it out.
Old April 23rd, 2010, 05:52 PM   #11 (permalink)
Brandon Cur's Avatar
Lemme know what you find, chipbutty!
I'm itching to do the same to my tele.
"If you're going to kick authority in the teeth, you might as well use two feet." - Keef
Brandon Cur is offline   Reply With Quote
Old April 23rd, 2010, 06:05 PM   #12 (permalink)
voodoo_idol's Avatar
The only problem with that plan is that a P90 is taller and narrower than a HB.
[Edit: Nevermind, see my correction below.]
http://www.seymourduncan.com/product...ges/sh-1.shtml
http://www.seymourduncan.com/product...s/sp90-2.shtml
There are plenty of P90 options sized like a HB -- Duncan, GFS, Tonerider, etc.
http://www.seymourduncan.com/product...h901_phat_cat/
http://store.guitarfetish.com/me90glbltral.html
http://www.tonerider.com/pickups/r90spickups.html
voodoo_idol is offline   Reply With Quote
Old April 23rd, 2010, 11:13 PM   #13 (permalink)
P-90 fits fine in the neck route on my MIM body:
Dirty Steve is offline   Reply With Quote
Old April 23rd, 2010, 11:16 PM   #14 (permalink)
mgwhit's Avatar
Cool. I'm pretty sure mine (1991?) doesn't, but sorry about the mis-info. What year is yours?
Old April 23rd, 2010, 11:20 PM   #15 (permalink)
Not sure of the exact year, but mid-00s.
Old April 23rd, 2010, 11:47 PM   #16 (permalink)
@Dirty Steve
That's exactly what my tele looks like currently but with a tonerider rebel 90 in the neck. I want to put a real p90 in though. Was the install fairly easy?
Old April 23rd, 2010, 11:49 PM   #17 (permalink)
you have it reversed my friend
Old April 23rd, 2010, 11:50 PM   #18 (permalink)
Thanks for that info. Taking another look at the dimensions I linked above, I was initially looking at the HB dimensions from mounting hole to mounting hole (3.063 in.). Assuming the MIM is routed to fit the outside dimensions to the tip of the HB mounting brackets (3.315 in.), the route does indeed appear to be long enough to handle a soapbar P90 (3.300 in.).
Old April 23rd, 2010, 11:56 PM   #19 (permalink)
I was just clarifying when you posted, but as for the top (surface) dimensions the P90 is indeed taller and narrower. Not that that matters when you have to route for the mounting brackets too.
Old April 24th, 2010, 12:19 AM   #20 (permalink)
@Dirty Steve
No harder than body-mounting a standard Tele neck pickup.
I had more trouble finding a pickguard to fit. I bought a pre-cut guard, but the the pickup hole wouldn't align with the body rout. Ended up cutting my own from an Esquire guard.
