Texas Special neck pup double ground
Why the neck pup of a Texas Special set have a separate ground (three wires). How should I solder the black and yellow wires (I have a CRL three position switch)
Thanks anyone replies Cheers Fabio
Sleep tight, my child, sleep well For I'll be at your side That no shadow, no darkness, no tolling bell, Shall pierce your dreams this night |
Here is how the pickup is wired with a 4-way switch.
![]() For a 3 way switch just tape up the yellow wire, it is a separate ground wire for the neck cover to be used with the 4-way. The 4-way gives you the bridge and neck in series(noise cancelling as well) as opposed to the parallel configuration with a 3-way. |
For a three-way, you should run the extra (yellow) wire to ground -- not tape it up -- so that you get the shielding function of the cover. On regular pups, the cover tab is connected to the black ground wire eyelet; for the TS pups, they just run a separate wire.
Of course, I don't see anywhere in my post that says it'll actually work... |
#4 (permalink) | |
So I 've just to solder the yellow to the volume pot...
