Old January 2nd, 2010, 09:45 PM   #1 (permalink)
DiMarzio True Velvet
I just installed the True Velvet in my Tele 52 reissue, both of them, plus the 4 way switch.
I recorded some samples if you are interested to ear how they sound like. the switch order is always from the bridge to the neck:
B, B+N(parallel), B+N(series), N
the amp is the Epiphone Valve Junior. There is no compression and I didn't touch the volume between the different sets:
http://pguiducci.com/tmp/tele_true_velvet_1.mp3
http://pguiducci.com/tmp/tele_true_velvet_2.mp3
The neck pick up has almost double output than the original, at least now I'm going to use it even alone.
mazapegul is offline   Reply With Quote
Old January 3rd, 2010, 11:13 AM   #2 (permalink)
martin82's Avatar
The TV neck is a great pup. I have it matched with a Dimarzio Pre B-1 bridge pup.
martin82 is offline   Reply With Quote
Old January 5th, 2010, 04:21 PM   #3 (permalink)
I need to correct myself. The order of the sample recorded is not:
The following is the correct 4 way switch order:
bridge, bridge+neck(parallel), neck, bridge+neck(series)
the 4th position (the pups in series) sounds similar to an humbucker.
Sorry for the mistake.
Old January 5th, 2010, 04:55 PM   #4 (permalink)
smsuryan's Avatar
i have a strat build going currently with only two pups...a red velvet at the bridge and a true velvet at the neck...the neck has 3 BROKEN TUNER SCREWS i have to take out...bah!!! but im stoked you started this thread im anxious to see what this thing sounds like even though i wont be keeping it...
Bark less. Wag more.
smsuryan is offline   Reply With Quote
