Wilde Pickups by Bill & Becky Lawrence Simmons Amp Repair Lace Music Products Acme Guitar Works GuitarSale.com Hahn Guitars Warmoth.com
Old November 28th, 2009, 01:21 PM   #1 (permalink)
Agave_Blue's Avatar
Adding a Humbucker
2004 MIM Standard.
I've been thinking about adding a Humbucker in the bridge position and leaving the single coil in the neck.
I've read that with Humbuckers you usually want 500k pots.
What do you do if you have a mix (1 of each H + S)? 250k pots or 500k pots?
Have not committed yet, just thinking about it.
Originally Posted by Ben Franklin
Beer is proof that God loves us and want us to be happy.
Agave_Blue is offline   Reply With Quote
Old November 30th, 2009, 11:39 AM   #2 (permalink)
Agave_Blue's Avatar
Hmmm. The silence is deafening.
Perhaps:
- It's a dumb quesiton? Dumb idea?
- Been asked a thousand times?
- No one knows a "good" answer?
- I'm too new to deserve an answer? ;-)
Any help or a point in the right direction is appreciated.
Old November 30th, 2009, 11:45 AM   #3 (permalink)
BritishBluesBoy's Avatar
Not a dumb question at all. It is more common to put a humbucker in the neck and keep the traditional Tele bridge though. You'll have to do some fairly major surgery on your body to make the humbucker fit in that slot whereas it is already routed for a hummer in the neck... Also you'll need a new bridge. Just a thought.
Have a look at the Seymour Duncan website for wiring diagrams. Lots of good info there.
BBB.
Old November 30th, 2009, 12:08 PM   #4 (permalink)
mgwhit's Avatar
Perhaps:
Been asked a thousand times. Search a bit. In short, there's no perfect solution.
If you really do put the humbucker in the bridge, I'd start with 500's. Unlikely that your neck single coil will be too bright.
mgwhit is offline   Reply With Quote
Old November 30th, 2009, 12:53 PM   #5 (permalink)
Jammin'John1's Avatar
No
Yea,it looses it's Teleness if there is no ashtray tele pup.
Of course the standard answer is that a 'bucker "needs" a 500k pot.
A 500 k pot helps the 'bucker to have more treble when it's wide open.
What I don't like is that when you turn down the 500k pot the trebles go away VERY FAST !
I prefer to use a 250k and turn the treble up a little on my amp. YMMV
mgwhit is right about "I'd start with 500's. Unlikely that your neck single coil will be too bright."
That's true and if you are the type of player that leaves your volume full up all the time that will work.
I constantly use the volume/tone on my Tele and I don't like how fast the sound gets muddy !
JJ
Tele's & Tweeds an accident ?
I DON'T THINK SO !
Jammin'John1 is offline   Reply With Quote
Old November 30th, 2009, 02:31 PM   #6 (permalink)
One thing to look at is the spacing of the pole pieces on your humbucker. You'll want a "trembucker" for a fender-style bridge due to the wider string spacing.
68thinline is offline   Reply With Quote
Old November 30th, 2009, 02:36 PM   #7 (permalink)
What about one of these:
http://www.seymourduncan.com/product...ttle_59_for_t/
BBB.
Old November 30th, 2009, 06:14 PM   #8 (permalink)
Agave_Blue's Avatar
Originally Posted by BritishBluesBoy View Post
That's EXACTLY what I am thinking about. Or the single coil Quarter Pound.
Thanks everyone for the replies.
It'll be a while before I decide and change since I want to go to a 4-poisiton switch at the same time. So, I'll do the whole harness and pickup(s) at the same time.
Old November 30th, 2009, 11:59 PM   #9 (permalink)
telesparkle's Avatar
i use 500k but is really depends on the type of pickup and the tone you are going for, i put a dimarzio tone zone T in the bridge position and it works well for 80's rock, it also sounds great in the middle position with the Area T neck. they also make the Fast Track T for a more traditional bridge pickup that is humbucking. i would not rerout the bridge pickup cause it's not really worth it, it changes the character of the tele too much.
telesparkle is offline   Reply With Quote
Old December 1st, 2009, 12:19 AM   #10 (permalink)
jrich99's Avatar
beat me to it.....
jrich99 is offline   Reply With Quote
Old December 1st, 2009, 09:33 AM   #11 (permalink)
Hello, I personally love 250k pots with humbuckers. They sound so warm.
teletyler is offline   Reply With Quote
adding end plunges to a humbucker rout? appar111 Tele Home Depot 29 April 1st, 2010 01:17 PM
Adding Humbucker to a Hwy 1 Wahl Of Sound Just Pickups 10 February 19th, 2010 07:52 PM
need help adding a amini humbucker in the neck flatheadfever Tele-Technical 8 September 17th, 2008 05:13 PM
Adding a 2nd humbucker to my Tele philcoleman Tele-Technical 0 May 1st, 2008 04:30 PM
I'm adding a neck humbucker and need some wiring advice! markophonic Just Pickups 8 December 6th, 2004 01:11 AM
