Neck p'up suggestions - a little more clarity?...
Advice needed!
I'd like to get a more useful neck pickup to replace the stock one in my MIJ 50s RI. It'll be complementing a Duncan Broadcaster I've had in the bridge for ages, and which I'm completely content with. Now, I'm happy with the sounds I get in the middle position, so I'm loathe to wander too far afield tonewise. Basically, I'm looking for a little more clarity whilst retaining that inherent "dark" quality of the Tele neck, so nothing over-trebly or Stratty...just something that sounds unmistakeably Tele-ish, output in the vintage ballpark, with a little less of the woolly muffle going on. Also, I'm not looking to route for a bucker or anything, and would rather it had the classic chrome cover. Has to be affordable, too. |
you might try a "nickel-silver" pickup cover to salvage your existing pickup ... they aren't muffled to the extent of the chrome-plated brass.
#5 (permalink) | |
I have a GFS Fatbody Alnico neck pup in my CV and I love it. It is certainly great bang for the buck but however - it is definitely on the 'stratty' side. And Darnweight had suggested thats not his aim. I'd also suggest just changing the cover, or, leave it uncovered / semi covered *if* the design safely permits, and you are comfortable giving it a go.
[ebaY sniper, enthusiastic scavenger of underrated Squiers, ham-fisted assembler of Partscasters] |
I use a Fender Vintage Noiseless neck pickup and it's clear as a bell.
You can also consider rewiring so that the tone control is only on the bridge pickup, or, even better, do the 'Gibson '50s wiring' trick where you run the tone pot off of the output instead of the pickups. Separating the tone pot from a pickup adds a bit of presence and openness to the sound. Also makes the volume control more usable too by keeping more treble when you turn down. To do the '50s wiring' you just move the wire going to the tone pot so that it's coming from the middle tag on the volume pot (where the wire from the input connects). If you are interested let us know and we'll give you a clearer explanation. |
#9 (permalink) | |
I guess I'm looking at the non-boutique end of the spectrum, by which I mean your Duncans, Dimarzios, etc....right on down to your GFS level stuff. |
Before you try anything else set a slightly brighter tone on the amp until you get the sound you want from the neck pickup. Now go to the bridge and roll off the tone pot on the guitar. When this sounds good take the knob off and reattach it so that the screw points straight up at this sweet spot.
You can then adjust on the fly
cheers fakeocaster |
#16 (permalink) |
Afraid I honestly don't remember...made the change over 10 years ago now, and haven't opened her up since. Part of the reason I'm considering the neck p'up change now is that the 3-way switch is beginning to fail, and if I'm replacing that I may as well consider this upgrade as well whilst I'm at it.
#17 (permalink) |
Thats the issue for me, I LOVE the middle position, so need to keep that tone at all costs. Many of the "improved" strat-like tele neck pups really take the middle position off-track, IMO. For a budget pup, I'd highly recommend a plain old MIM 50's Classic tele neck, you can get em fopr $20-25 all day on eBay, great tone alone, and keeps the killer middle tone. For higher price, a Barden neck just kills.
#18 (permalink) | |
The best, least expensive but most effective way of having a clear rhythm tone ! |
#19 (permalink) |
i have kind of a different approach, the am dxl i play has the "delta tone" no load tone pot. tone knob wide open is a bypass, and it kind of "sits" into place. this thing does wonders for brightening a neck pup. cheaper than a pup swap and you'll get results.
...took the tube out of the v1 spot and replaced it with a dilithium crystal (like on star trek)... |
#20 (permalink) | |
Telewacker |
#21 (permalink) |
fwiw, the 50s mod works when turning vol pot down but won't 'brighten' and inherently muddy neck PU.
The cheapest option I can think of is to disconnect the neck PU from the tone pot. That alone adds clarity. Combine this with adding any additional treble at the amp as per fakeocaster's suggestion and leaving the tone pot set the bridge position 'sweet spot' you can achieve what you want for zero expenditure. I've done this to good effect in the past. Also will +1 on the MIM Classic 50s neck PU for an excellent tele sound - not stratish, or hyped at all, but clear and detailed. A good pickup, regardless of price. |
#22 (permalink) | |
Still may swap the neck p'up out further down the line, when money's a little less tight, so if anyone has any other suggestions then, please, suggest away! |
#23 (permalink) | ||
Good luck.
Jemima surrender. That's all ya hafta do. I'll bring over my Fender & I'll play all night fer you. |
#24 (permalink) |
Tonerider
I've got a Tonerider Classic Blues strat pickup in the neck of a Tradition J.R. Reid Tele and it's beautiful sounding. I actually like it better than a Twang King neck pickup I used to have in another guitar. Lots of bite and great if you like using your neck pickup for lead.
| Improving Clarity of neck p'up. | spearlymatt | Just Pickups | 14 | August 6th, 2009 05:13 PM |
| Clarity One - clean tone Mr. Les Paul type instrumental using Clarity Preamp. | wnorcott | Twanger Central | 0 | May 2nd, 2009 09:06 PM |
| Tele Bridge P'up suggestions ? | bongofury | Just Pickups | 6 | September 28th, 2007 11:31 AM |
| B & B Lawrence P'up combo suggestions | StuH | Just Pickups | 4 | June 1st, 2007 02:21 PM |
| coverless neck p'up | dill | Tele-Tech | 2 | October 7th, 2004 02:44 PM |
