Tele wiring question...can I get series/parallel/bridge only on a 3way?
Now that I have several guitars equipped with 4 way switches I find that I never use the neck pickup alone...Im on the bridge pickup most of the time but on a few songs I'll use the bridge/neck parallel and I really like the bridge/neck in series for slide work...but I never use the neck pickup alone...just wondering if I can get what I want out of a 3 way.
So to clarify...can I wire a 3 way switch to give me bridge only/both parallel/both series?
I cried the day Buck Owens died... http://www.myspace.com/pickingfool http://www.myspace.com/stevehelmsband |
Yes, wire it like a 4 way, but don't wire the neck only position lugs on the switch. If you're using the diagram that comes with Fender 4 way switch, ignore (i.e. imagine that lug does not exist) the 4th from the left on top (nothing is connected to that one) and 3rd from the left on the bottom (one of the ground connections).
Thanks guys...I'll give this a try when I get home
Well...I was able to wire my guitar up the way I wanted but then I screwed the neck pup down too far and trashed it...I guess it bottomed out on the wires so while I continued to screw it down it bowed in the middle and popped apart.
For now I'm calling this guitar the "Unintentional Esquire" :)
| series/parallel wiring for a bridge rail pup possible? | scoots | Tele-Tech | 9 | September 23rd, 2009 03:49 AM |
| wiring diagram for using tele 3-way switch for series/parallel/split | appar111 | Just Pickups | 4 | June 14th, 2009 11:59 PM |
| wiring: series / parallel | f69tele | Tele-Tech | 7 | March 28th, 2006 09:18 AM |
| 4 way series/parallel wiring diagram | cacibi | Tele-Tech | 2 | January 22nd, 2005 07:45 PM |
| Series vs. Parallel wiring??? | Bluedawg | Tele-Tech | 14 | July 26th, 2003 08:29 PM |
