Looking for 52 hotrod tele wiring diagram-HELP
Hi All,
I'm going to put in the Seymour Duncan vintage mini humbucker into my new american standard telecaster and I have looked everywhere for the wiring diagram for a 52 hotrod tele, so I can be sure to wire it right. Has anyone seen the wiring diagram for the hotrod tele? thanks so much!!
*Spank The Plank* Fender '52 AVRI Telecaster Fender '57 AVRI Stratocaster Fender '06 AS Telecaster 60th Anniv. Fender '09 AS Telecaster w/ Mini HB Fender '65 RI Twin Reverb/Blues Junior HR |
I've never found that wiring diagram, and as you probably know it's not up at Fender.com . . . but I did find mention, in an answer to the same question, as follows:
"It should be no different really then a "humbucker in the neck" diagram from seymour duncans site." So try this one: http://www.seymourduncan.com/support...1sing_1humneck
Everybody gets the blues sometimes . . . . Best thing to do is rock 'em out. |
I've never opened the guts of mine, but I'm pretty sure it's wired like the usual Tele. If the minihum comes with 4 conductors, just solder the red wire with the white together and then the pup works like a single coil (check Seymour notice to know which conductor will then work as the + or the -).
Also don't forget the '52 hot rod uses 375k pots, which helps for a brighter tone. |
I've got the link to the pdf on Fender's website at home. If nobody else posts it, I'll post it tonight. It's on Fender's site, they just don't link to it from the wiring/parts section.
From what I remember it has: 2 375k Alpha pots and a .022 uF cap. The braided wire on the humbucker gets soldered to the volume pot. Everything else is the same. |
#7 (permalink) | |
I just ordered 2 of these.
http://www.darrenriley.com/shop/cart..._detail&p=1883 and according to the wiring diagram for the American Standard Tele it comes stock with the .022 uF cap.
Here is the link to the Fender web site:
http://www.fender.com/support/diagra...100232BPg2.pdf The parts list is here: http://www.fender.com/support/diagra...100232BPg3.pdf |
#11 (permalink) | |
thanks so much!!!! perfect. Now if I can only hold the soldering iron w/o shaking.
#14 (permalink) |
Well, the part number is different, and they have different names, so I would guess they are different, but of course with Fender, you never know. They don't sound the same to me, but then I've only just acquired a VHR 52, and haven't yet really done an A/B comparison test . . .
#16 (permalink) |
Update: well I'm just waiting for my SD MiniHB to show up, they are on back order. I have everything else for the American Standard HotRod Project.
thanks everyone for your help. I'll post pictures of the process.
| Need wiring diagram for Tele | HeywoodHoagland | Tele Home Depot | 5 | March 26th, 2009 05:23 PM |
| Me vs. Esquire Wiring Diagram. Diagram wins! | fuzzferatu | Tele-Tech | 9 | February 29th, 2008 09:56 PM |
| JD Tele wiring diagram? | Ringo | Telecaster Discussion Forum | 9 | November 26th, 2003 10:44 AM |
| Anybody have a tele wiring diagram for.... | John E | Tele-Tech | 6 | October 10th, 2003 10:22 AM |
| JD Tele Wiring Diagram | boymambo | Tele-Tech | 6 | March 28th, 2003 04:27 PM |
