HOT, Tele-sounding twangy pu's ?
Tele people . . .
. . . i am saking this question for someone else (non forum member). He is looking for Hot tele pu's to drive his *amps a little more, but must deff retain that distinctive Tele twang. He played someone elses Tele w SD Cool Rails, and was NOT impressed * vintage Princeton & newer Pro Jr. Thanx folks
Guitar -->Fuzz -->OD -->Trem -->Delay -->'66Bassman. |
NO Affiliation.
Check these out ... bridge dirty sound clip is good and twangy. I plan to use this on my build.. http://www.axetec.co.uk/axetec%20gui...ickups_103.htm |
Lollar Special T in the bridge and Lollar Charlie Christian in the neck. They will rock and twang with the best of them. I promise.
Jemima surrender. That's all ya hafta do. I'll bring over my Fender & I'll play all night fer you. Last edited by caliban335; October 21st, 2009 at 05:00 PM. |
C'mon now, we all should have learned this by now. It's a zero-sum game.
If you depart from vintage specs, you depart from vintage sound. If you want "hot" output, the pickup is not going to sound the same as one with "vintage" output. It might sound good, it might even sound better to you, it might not sound different by much, but it **will** sound different from a vintage-spec pickup. Maybe the OP's friend should get a Tele he/she likes the sound of, then use some sort of booster to increase the gain - a Barber Launch Pad, a T-Rex (was Jauernig) Luxury Drive, or something similar. |
#7 (permalink) | |
Yes, either use a box or go older school and just turn up ;)
www.bourbondynasty.com |
Hotter passive pickups -> more windings -> less twang, more mud.
The only other way to get more passive output is to use very powerful magnets, but then you have additional tradeoffs. Preamps are the best overall answer. They can be stompboxes (including some of the stompbox EQ units out there) or can be "built-in" to the pickups like EMGs. EMGs are actually a great example of the type of high-output/high-fidelity sound that active PUPs can achieve. They are perhaps a good choice, and quiet to boot.
---------- Tech Geek and Sensitive Artiste String bender ordinare! |
#10 (permalink) | |
Are you referring to those EMG PA2 "boosters" ? Just how much extra gain, or volume does the "4-pos-mod" give you ?
Hot and Twangful
Don Mare's Super Sport tele bridge pickup is designed exactly for this purpose.
Check it out: http://www.buckcannon.com/pickupsfortele.html Fifth one down. There is a short (very short) sound clip. My experience is that it sounds fatter and has a lot more snarl in the mids than you can hear on this clip. Great tones and harmonics when you drive a tube amp hard! |
LeoSounds MudCats from www.leosounds.de are higher output pickups that are also twangy.
#18 (permalink) | ||
The PA-2 is not properly loaded for passive pickups - the input load is around 10K. A proper preamp for passives should have an input impedance of about 1Meg.
#19 (permalink) |
i've found that the scns are very volume knob sensitive. roll back for a more full even sound and open it up for a bite. been playing out alot lately and i like how these sound with some volume behind them. very clear. the neck pup(which is my fav) is kind of strat-ish and i can get a nice punchy twang out of the bridge. they sound good combined and they take pedals well. versatile too. bill lawrence pups
...took the tube out of the v1 spot and replaced it with a dilithium crystal (like on star trek)... |
#21 (permalink) | |
In series, the output voltages of the two pickups are added together. So, your guitar's output will be approximately doubled in that switch position. The tone is a little fatter in that position than it is in the combined-parallel position. If your friend turns up his amp far enough, can he get overdrive with his current pickups? If so, hotter pickups won't do much of anything for him except a slightly better S/N ratio, IMO. I have the Don Mare Supersport bridge - Stelly neck set. Absolutely beautiful sounding set, a little less bright than my Fender OV set. |
#23 (permalink) |
Amazingly, the brige PU on the CV is a total butt-kicker. I use the stock CV for bite and pure twang, not my Amer. Std.....and my American Tele has a Lindy Fralin on it! (Fralin for more depth).
#27 (permalink) | |
Not an 80's pointy-point shread stick fan, but this one atleast looks good - colour wise
#28 (permalink) | |
| clean tele clip using vibrolux, twangy bluesy whatnot | Joe Gagan | Twanger Central | 4 | June 17th, 2008 03:21 AM |
| Twangy Strings for a Tele | Lerb21 | Telecaster Discussion Forum | 14 | February 2nd, 2008 11:05 PM |
| SCN PU's in a Tele? | resonator | Telecaster Discussion Forum | 3 | April 24th, 2007 01:36 PM |
| Hot quality, twangy, single coily Tele pickups ? | Soulgolem | Just Pickups | 10 | January 29th, 2006 12:13 PM |
| What affordable Tele vintage sounding PU's are out there? | randysmojo | Just Pickups | 10 | August 9th, 2005 09:14 PM |
