Old September 16th, 2009, 07:23 PM   #1 (permalink)
Wiring Question - Novak Pickups
Based on recommendations from this board I bought the JM-V for the neck and the JM-90 for the bridge. The pickups did not come with a wiring diagram so my questions are as follows.
1) I replaced the neck pickup and put the black wire where the black wire went and the yellow where the white was. Is this correct?
2) Where do I put the bridge wires? The original pickup had black and white wires where as the new pickup has green and yellow.
Thanks
TommyChung71 is offline   Reply With Quote
Old September 16th, 2009, 09:42 PM   #2 (permalink)
braderrick's Avatar
I'd say green should be ground (back of the pot casing) and the yellow to the switc (hot).
braderrick is offline   Reply With Quote
Old September 17th, 2009, 04:38 AM   #3 (permalink)
Mark Moore's Avatar
Email Curtis and ask him. He won't bite. curt@curtisnovak.com
"Whoops." -Waylon Jennings
Mark Moore is offline   Reply With Quote
Old September 17th, 2009, 06:47 AM   #4 (permalink)
braderrick's Avatar
I guess you could email and wait patiently for a reply but if it were me I'd be itchin' to hear and play that thing. Worse case, the wires are backward and the bridge pickup will be out of phase with the neck pickup. If so just swap the wires back, no biggie and it wont damage anything.
Old September 17th, 2009, 04:02 PM   #5 (permalink)
castpolymer's Avatar
Ditto! I have a set of his pups and he is very easy to contact.
castpolymer is offline   Reply With Quote
Balancing pickups- a technical/wiring question kayarcee Tele-Tech 4 March 29th, 2009 10:26 PM
Curtis Novak Pickups Are Exceptional! castpolymer Just Pickups 16 August 23rd, 2008 03:01 AM
Curtis Novak Pickups. Red Planet Just Pickups 3 July 24th, 2007 11:14 AM
Question about wiring my new BL Keystone pickups... Mwieczorek Stratocaster Discussion Forum 6 August 23rd, 2006 11:44 AM
A pickup design question (pup makers? Lollar? Novak?) fabien Just Pickups 4 July 2nd, 2003 05:24 PM
