Push/Pull Pot or 4 way switch (I need some clarity)
My Tele seems to need a set up. Since I will take it in to my guitar guy, I think there is a mod I have been putting off that I will have done, and that is to get my Keystones to sound like humbuckers or just a fat sound. Is that running them in a series or parallel? I forget. Is there any difference between the push/pull pot and the four way switch or do they basically do the same thing?
I believe its in "series". I like having the 4 way way switch myself, it's easier to get to, and on some teles the body route may not be deep enough for the push/pull.
I use a 4 way because I'm just not a "layered" sound guy, I like everything there where I can see it. And watch out when you get that mod done...it's lethal!
"I've always considered myself a hobbyist" |
I am leaning more towards the 4 way switch. But they, the switch and the push/pull pot do the same thing, right? One thing that I do, quite often when I am playing, is hit the switch with my hand while strumming and switch pick ups on accident. In this case, the push/pull might be better for me.
If you're hitting the switch by mistake, have you thought about swapping the control plate around (backwards) so the switch is at the back ?
I did the 4 way switch and love it. . . . and as was stated by mijstrat above, I like to be able to see exactly what position I'm in, even if I can hear it anyway.
Life is short; play loud! www.myspace.com/theskinnersband www.myspace.com/theboneyarsedboys |
#6 (permalink) | |
>And do you agree it is a lethal, kicking mod?<
Well I wouldn't call it lethal. It will make your tone a little fatter, give higher output and will drive the amp with a little more power (series most notiocable with some overdrive). It is pretty nice and adds some kick but don't expect that you plugged into a Marshall stack all of a sudden ! I'm not trying to down play the mod though. It is worth it by all means. |
I got a 4 way switch with the series position in no 4. Quite an interesting sound, but i like the neck-pickup-alone sound better and use it far more often; but position 3 is not quite easy to find.
So what i'm gonna do is to swap positions 4 and 3, so i have the single pickups on 1 and 4 and the the twin pickup-sounds on 2 and 3.
Using an apostrophe for plural sucks |
Currently, I live on the neck PUP with my Keystones. I use the bridge for leads, but have been going there from time to time to play some blues and country. The neck sounds so good, to my ears. I like a darker, warmer tone. I am excited to see how they sound with the new wiring and 4 ways switch. I dropped my Tele off today at my tech's shop. I went with the 4 way switch instead of the P/P pot. To be continued...
| new switch plus push pull | Hollis613 | Tele Home Depot | 1 | July 28th, 2009 01:37 AM |
| 5-way switch, push/pull pot, three pickups | Axis29 | Tele-Tech | 0 | February 25th, 2009 05:44 PM |
| Push Pull Phase Switch | Apok | Tele-Tech | 2 | April 4th, 2008 11:26 PM |
| Baja S1 Switch, or 4 way and push pull? | Ringo | Tele-Tech | 2 | June 12th, 2007 02:51 PM |
| 3way + push-pull vs. 4way switch | batty | Tele-Tech | 1 | June 7th, 2004 06:29 PM |
