Old September 13th, 2009, 09:10 PM   #1 (permalink)
scratchy/staticy neck pup keystone
I am getting scratchy and static like noises using the neck keystone pup. Bridge is fine. It is worse when i use bare fingers without pick. I get noise when i strum, and when I touch the neck pickup adjustment screw. Is this something a cavity shield would help? I had heard/read that fender MIMs have shielded cavities but it doesnt seem like they are, unless they use clear shielding paint. I dont know what shielding paint looks like,never used it. Anyone know what i might do to fix this issue?
baldy5000 is offline   Reply With Quote
Old September 14th, 2009, 12:11 PM   #2 (permalink)
sbolt's Avatar
I would recheck the solder joints.
sbolt is offline   Reply With Quote
Old September 14th, 2009, 12:15 PM   #3 (permalink)
Did you make the cover on the neck PUP [blacklead] the hot or do an out of phase with the neck pup via 4 or 5 way switch with out isolating the neck pickup cover's ground?
Hackguitarist is offline   Reply With Quote
Old September 14th, 2009, 03:10 PM   #4 (permalink)
the neck pickup has no cover. I just wired it the way it was wired before, three way switch.
Old September 14th, 2009, 03:13 PM   #5 (permalink)
VENDOR
Telenator's Avatar
Sounds like you might have picked up some static electricity in your pickguard. Dry rubbing your pickguard with a dryer sheet. They're anti-static and most often solve the problem you're describing.
Dogs have the right idea!
www.telenator.com
Old September 14th, 2009, 06:17 PM   #6 (permalink)
surfco's Avatar
+1 on the dryer sheet.
surfco is online now   Reply With Quote
Old September 16th, 2009, 01:40 PM   #7 (permalink)
yeah i got the dryer sheets and voila', no more noise. And I got Bounce free, so you dont get all the nasty perfumes and dyes. Thanks guys!
Chrome Keystone neck pickup Q DaleH Just Pickups 1 July 25th, 2008 04:55 AM
Staticy Neck Doug Ferguson Tele-Tech 11 June 23rd, 2008 03:03 PM
Chromed neck Keystone arrived ! Scotland Just Pickups 13 May 14th, 2008 10:42 PM
Keystone neck pup in chrome? Is it soon to be a reality? YES! Arlo Just Pickups 17 November 6th, 2007 05:20 PM
staticy noise from TRRI Mark N Amp Central Station 1 July 23rd, 2007 10:23 PM
