Do the Tex-Mex Tele bridge pickups not come with the base plate? I have these pickups in my tele, and I've always thought there could be more twang.
“Bad taste creates many more millionaires than good taste.” -Charles Bukowski. |
Here's a sloppy plate install on a Tex Mex:
![]() ![]() Later ones, I left off the black screws and aligned the plastic to the threads in the Allparts base plate, and installed a ground lead from the plate to ground wire. I lopped off the added thickness or flange of the plastic so the plastic and steel plates would lie flush. - Shoe Goo or similar is my adhesive - reversible product.
When i listen |
No, it's and inductance deal.
Here's what is said about Fender Original Vintage bridge pickup: The bridge pickup sports the traditional copper-plated steel base plate for that extra midrange. TDPRI resource: http://www.tdpri.com/resources/tele-...ate-materials/ |
So would I want to use a steel base plate? It looks like Boris uses steel.
Do I need to put shoe glue between the plate and magnets? Or would it be better to not put anything in and just screw it on? |
Where can you acquire the necessary metal for a baseplate fix on a bridge pickup? And exactly what is the best way to cut and affix it to the pickup?
Today is only yesterday's tomorrow If practice makes perfect,and no one's perfect,then why practice? |
#15 (permalink) | |
1) No metal to metal connection between the magnets and the base plate; 2) Microphonic Squeal is likely an issue if there's nothing to keep the metal plate from vibrating against the plastic bobbin. But I tried one the other way, just lightly held on and in that case, it did seem to work.
When i listen |
#16 (permalink) | |
All the rest of mine are from Allparts; thinner chromed steel. I think Mojotone has the copper ones. I might order from there.
When i listen |
| how do you measure pickup impedance? | jivetrain | Just Pickups | 24 | February 8th, 2009 02:51 PM |
| impedance question | stxrus | Amp Central Station | 5 | June 2nd, 2008 06:04 PM |
| Impedance? | fungusyoung | Amp Central Station | 6 | October 14th, 2006 07:42 PM |
| Low Impedance Pickups | Robin Nahum | Just Pickups | 1 | September 28th, 2005 11:18 PM |
| Please Help Me with Impedance!! | Wild Rice Chris | Amp Central Station | 9 | October 7th, 2004 04:22 PM |
