Old July 6th, 2009, 09:10 AM   #1 (permalink)
Noisy pickups help!
Eversince I changed my tele neck this morning, my pickups buzzes like hell! I did NOT touch any wirings or the pickups at all. All i did was rmove the pickguard, remove the old neck and put it back together. Now when i touch the pickups with my fingers, it makes a crackling irritating buzz, when untouched it makes a constant shrill buzzing. I have never wired my pickups before, let alone dismantling them and there were no problems before the neck change. Anyone knows what may be the problem here? Thanx, it's driving me crazy!
retrocaster is offline   Reply With Quote
Old July 6th, 2009, 09:36 AM   #2 (permalink)
Stuco's Avatar
Make sure the ground wire to the bridge didn't come loose.
-"You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do" J. Garcia
Stuco is offline   Reply With Quote
Old July 6th, 2009, 10:46 AM   #3 (permalink)
Ground wire
Hmm.. I have a humbucker on the bridge cavity, all is snugly fit that i can hardly see any wires. I really hope it's not some wiring problems tho. Any other possible cause? Your help is greatly appreciated.
Old July 6th, 2009, 11:49 AM   #4 (permalink)
Stan Martin's Avatar
more info please
what type of neck pickup did you have before and did you replace it with a similar one? are the pickups in-phase?
Stan Martin is offline   Reply With Quote
Old July 6th, 2009, 02:37 PM   #5 (permalink)
spauldingrules's Avatar
Probably something metal touching something else metal that it's not supposed to be touching.
spauldingrules is offline   Reply With Quote
Old July 7th, 2009, 02:08 AM   #6 (permalink)
pickups
It's a partscaster, the pickups came already attached to the body, so I'm not sure what they are, but there were no problems before neck change. I did'nt replace any electrotronics or parts at all, just swapped the neck.
Old July 7th, 2009, 02:16 AM   #7 (permalink)
I'll check the cavity again to see if that's it. Thanx all.! appreciate it.
