Old July 2nd, 2009, 01:10 PM   #1 (permalink)
How do you match pickups?
I have two Standard Series Squier Fat Teles. One will keep the humbucker and one will get a P-90 from an Old Kraftsman guitar made in the late sixties. The question is, how do I match the bridge pickups to the neck pickups.
Here's what I've got for my neck positions: Squier Alnico II humbucker, Old Kraftsman P-90.
Here's what I've got for the bridge positions: Am. Standard, Duncan Designed w/brass base plate, two stock Squier bridge pickups.
All the bridge pickups are Tele style pickups.
Do I measure the resistance of each pickup and use the one that is the closest to the neck pickup?
Any help is appreciated.
J.D. is offline   Reply With Quote
Old July 2nd, 2009, 02:28 PM   #2 (permalink)
Mark Davis's Avatar
I just install them and adjust heights so they match in volume.
The ohms isnt always a good indicator of how loud a pickup is gonna be.
Old July 2nd, 2009, 02:52 PM   #3 (permalink)
Michael Murphy's Avatar
Location: I can hit the Pacific Ocean and/or Canada with a rock from here...
The past few years I have been using Esquires pretty much exclusively so it hasn't really been an issue...
-Michael
Charter Member S. Texas He-Man Emoticon Haters Local #316
Just an analog boy in a digital world...
Michael Murphy is offline   Reply With Quote
Old July 2nd, 2009, 03:35 PM   #4 (permalink)
One thing to have in mind is that the magnet is indeed a good indicator for volume.
I installed a SD vintage (Alnico 5) P90 in the neck of my CV Tele. It overpowered the stock bridge pickup (Alnico 3) even at the lowest height. I now have an Alnico 3 P90 with 8,000 winds (no idea what resistance) that matches the stock bridge pickup nicely.
If you are going for a hot neck pickup, either humbucker or P90, maybe the 250K pots are not going to be a good match anyways.
If you are going with a neck P90, it is also important to verify that the middle position will hum bucking... so you should at least test for polarity with a compass. The usual appears to be south-up with CCW for the bridge position and north-up with CW for the neck position, but some companies do things differently.
starjag is offline   Reply With Quote
Old July 2nd, 2009, 04:46 PM   #5 (permalink)
Both guitars came stock with 500K pots, so I'm good there. The humbucker sounds good with the stock Squier bridge, but I hate not to use one of the better pickups.
For what it's worth, the Duncan Design bridge is a TE-101 B that is rated at 6.75 ohms. Any experience with these?
What does CCW/CW stand for?
Old July 2nd, 2009, 05:14 PM   #6 (permalink)
Mark Davis's Avatar
counter clockwise and clockwise
Harmonic Design Tele pickups match for Vintage+ and advice on Z90 redboy_be Just Pickups 1 January 4th, 2009 01:27 PM
So the ohms match, how important is it that watts match? Steve G Amp Central Station 6 November 10th, 2007 06:35 PM
Mix 'n Match Pickups telechaser Just Pickups 0 October 18th, 2007 06:02 AM
match up fancychords Telecaster Discussion Forum 5 November 27th, 2004 07:41 PM
What would match a red Tele? TeleGeir Telecaster Discussion Forum 6 April 29th, 2003 04:36 AM
