Old June 30th, 2009, 06:29 PM   #1 (permalink)
JG806's Avatar
pickup height???
Where is a good place to start, in general, for Tele bridge pup? 5mm from the strings? Obviously there are many factors to get to the final right height for the user. Just looking for a recommended starting point. I'll adjust from there and find what I like.
"...you don't have to worry, cuz takin care of business is His name."
JG806 is offline   Reply With Quote
Old June 30th, 2009, 09:41 PM   #2 (permalink)
sjtalon's Avatar
1/8" bass 7/64" treble side....... fretting the stings at the last fret
sjtalon is online now   Reply With Quote
Old June 30th, 2009, 09:57 PM   #3 (permalink)
woodman's Avatar
i usually start with the two-nickel thang — slide a nickel under your high E so it sets on the pickup; hold string down at last fret; and lower string til it barely touches the nickel. then do the same thing with two nickels under your low E. this will generally get you in the ballpark. then touch them up by sound through the amp ... in my experience, higher settings will get you more deep bottom end; lower will thin it out, decrease boom and accentuate the twang. home in on the sweet spot as regards *your* guitar and amp. all else is theory. at least that's my theory!
Old June 30th, 2009, 11:52 PM   #4 (permalink)
Tony Reid's Avatar
Depends on the magnet type. A3 like to be up close and personal. A5 sound better a bit further away. YMMV
Tony Reid is offline   Reply With Quote
Old July 1st, 2009, 07:29 AM   #5 (permalink)
Amby's Avatar
+1
Amby is offline   Reply With Quote
Old July 1st, 2009, 11:17 AM   #6 (permalink)
surfoverb's Avatar
+1
I just do 1 nickel on both sides then lower the bass a tad and/or raise the treble some. This is cheaper than the 2 nickel method.
For an even cheaper method use a virtual nickel, a virtual nickel measures about 2mm.
"You released the ******* fury!"
Old July 1st, 2009, 11:46 AM   #7 (permalink)
garymaddox's Avatar
Ok... let me make sure I understand this process:
Put a nickel on the neck pup and fret at the first fret (F) then raise or lower the pickup on the treble side. Correct?
I do appreciate Surfoverb's money saving tip! I'd hate to have to take a loan in today's economy...
garymaddox is offline   Reply With Quote
Old July 1st, 2009, 11:55 AM   #8 (permalink)
surfoverb's Avatar
No. Fret the last fret with the nickel on the bridge pickup. Or just measure 2mm from the top of the pole to the bottom of the string with the last fret fretted (the virtual nickel, a nickel measure 1.95mm).
Old July 1st, 2009, 12:12 PM   #9 (permalink)
GuitarJonz's Avatar
+1, dial in the bridge pup first, then raise/lower the neck pup until you get the tone & output that you like for both neck & middle positions. With standard single coils, I've always found that a slightly less loud neck pickup adjustment gives better twang and spank in the middle switch position. If you adjust both neck and bridge to be perfectly balanced in volume, the middle position sounds too much like the neck alone.
GuitarJonz is online now   Reply With Quote
Old July 1st, 2009, 12:16 PM   #10 (permalink)
With the bridge pickup that close to the strings, doesn't that make it impossible to balance the volume of the two pickups? In order to get a balanced volume, I think you would have to get the neck pickup as close to the strings as possible, and the bridge pickup farther away. Or do you guys just live with the fact that one pickup is louder than the other and compensate some other way? I hate using the guitar's volume control, because it also rolls off some highs.
davidge1 is offline   Reply With Quote
Old July 1st, 2009, 12:32 PM   #11 (permalink)
surfoverb's Avatar
yeah depending on the output of the neck pickup...I prefer lower wind neck PUPs they sound better to me, I don't try and get them perfectly balanced, I think they sound better when theres more bridge than evenly matched. I do drop the bridge a tad if they are way outta wack. I put the neck as close as I can go, like 1.5mm or so.
Old July 1st, 2009, 01:15 PM   #12 (permalink)
surfoverb, What do you do to compensate for the change in volume when switching between pickups? Do you use the guitar's volume knob, or adjust it on the amp?
Old July 1st, 2009, 01:23 PM   #13 (permalink)
surfoverb's Avatar
volume knob
Pickup Height? SixStringSlinger Stratocaster Discussion Forum 15 September 14th, 2009 11:04 AM
Pickup Height tele_wah_fuzz Just Pickups 5 July 6th, 2006 03:10 PM
pickup height bsfan Just Pickups 2 March 30th, 2005 07:57 AM
Pickup Height? matt52 Stratocaster Discussion Forum 2 July 29th, 2003 02:27 PM
pickup height Wheelman_69 Tele-Tech 5 July 25th, 2003 09:28 PM
