Old June 14th, 2009, 10:25 AM   #1 (permalink)
appar111's Avatar
wiring diagram for using tele 3-way switch for series/parallel/split
Does anyone have a wiring diagram for using a standard 3-way tele switch for series/parallel/split coil?
I'll be getting either a Dimarzio rail pickup or a Duncan Lil 59 soon for an esquire and want to use the 3-way switch for this instead of a mini-toggle.
thanks!
appar111 is offline   Reply With Quote
Old June 14th, 2009, 05:38 PM   #2 (permalink)
Do you mean:
position1 : series
position2 : parallel
position3 : split (i.e. just one 1/2 of the humbucker)
and no bridge alone or neck alone at all?
cc9cii is offline   Reply With Quote
Old June 14th, 2009, 06:37 PM   #3 (permalink)
funff's Avatar
I've used this one on an Esquire - works fine.
http://www.seymourduncan.com/support...tic=esquire_hb
funff is offline   Reply With Quote
Old June 14th, 2009, 11:57 PM   #4 (permalink)
appar111's Avatar
Originally Posted by cc9cii View Post
Do you mean:
position1 : series
It's for an esquire, so there's no neck pickup to worry about. I'm looking for:
1 (i.e. the "back" position): bridge pickup (series)
2. bridge pickup (parallel)
3. bridge pickup (split coil)
Old June 14th, 2009, 11:59 PM   #5 (permalink)
appar111's Avatar
thanks man, I'll give it a whirl!
-J.
wiring a Dimarzio humbucker for series/parallel AND split coil appar111 Just Pickups 3 May 1st, 2009 11:42 PM
Help finding diagram for series/parallel with DPDT switch and 3 way Guitfiddler Telecaster Discussion Forum 6 February 23rd, 2009 05:49 PM
Neck humbucker coil split 5way switch wiring diagram...HELP Combsie Telecaster Discussion Forum 4 April 2nd, 2006 08:04 PM
4-way switch Series/Parallel on your Tele? 56tele Telecaster Discussion Forum 10 February 3rd, 2005 05:11 AM
4 way series/parallel wiring diagram cacibi Tele-Tech 2 January 22nd, 2005 07:45 PM
